Exhaust back pressure sensor eliminator
I want to make my own does anyone know what resistors I need and the wiring schematic for one? My factory sensor is broke at the connector. I really dont want to spend $100 for a new sensor and would really like to just make my own eliminator.
Back pressure sensor, I didn't know our trucks had those. Where is this located.
OHH yeah. I changed mine a while back. Spent the money cause I thought I had to. It is right in front of the engine below the fuel filter. It is a sensor pointing down connected to a metal tube which goes to the underside of the engine. I ended up replacing mine along with cleaning out the tube (they get clogged with soot, causing high backpressure readings i converted a reading from a scanner and found that mine was reading 55psi of backpressure when it should be about 14). There is a writeup on here about how to clean the sensor and tube and save money IF the sensor isn't just shot. I really think I ruined my sensor when trying to clean it....... but I learned from it!
The sensor isn't needed unless you still use the EBPV, mine has been gone for a while.
I finally got rid of the code from popping up by buying the dongle ![]() SP Diesel Main |
yeah but I think my truck is slightly defueling due to no exhaust back pressure sensor. and throwing the code p0472
Thats what I want but I want to make my own.
I have never seen any plans for this in the past and his was the only I know of on the market... Sorry
