Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Performance Parts
Old 08-17-2005, 08:08 PM
lakeydj lakeydj is offline
Post aftermarket
Anyone out there got any performance mod ideas for my 97 that they have tried or have heard of.
Old 08-18-2005, 09:52 AM
Andy Andy is offline
Administrator
Especially if your truck has an automatic transmission, I would look into that Edge Evolution. One of the problems that Fords have had throughout the years, with certain powerstrokes, is transmission problems.
Usually the problem is that Ford decreases fluid pressure in the Transmission during shift points. Well, during shift points is when you want that fluid pressure to stay steady, not drop in pressure.
Anyways, the Evolution not only gives you power, but its one of the few programmers that I know of that raises the tranny fluid pressure during shift points.
Thats what I would recommend.
Lem
Old 08-19-2005, 08:09 AM
Thanks for the info on the edge chip........i'll fore sure chech into
lakeydj
Old 08-19-2005, 10:44 PM
Hey lem,
Correct me if i'm wrong......but isn't the pressure in my 97's tranny controlled internally?
Old 08-19-2005, 10:56 PM
Administrator
Hmmm, that is possible. Maybe its just on the newer 7.3L's thats controlled by the computer? You could be right about that.
I know before Edge was even in biz, that my dad had a guy make the tranny have more pressure manually. I think they had to drill new holes and redirect fluid and such. Anyways, once he increased the fluid pressure, he stopped having to buy new transmission's every 20K miles.
For the 97, as far as chips go, edge, superchips, or the bullydog 4bank chip should work out nicely to give you more power and hopefully some better fuel economy.
After that, you might want to look into a new air intake and maybe a little bigger exhaust.
I've tried a lot of these things, just not on the early PSD's. But I hear they work well.
Old 08-19-2005, 11:05 PM
I'm pretty sure that you have to change pressure inside the tranny.....I think bully dog has a kit.....plate, springs, balls and valves........gonna check into it.....could you help me find out what the best chip is for my truck.......should i post it on one of the general forums.? thanks
Old 08-21-2005, 12:49 AM
purduefarmboy460 purduefarmboy460 is offline
Send a message via AIM to purduefarmboy460
I gotta agree with Lem, the edge is an awesome set up. I tried one in my 01, loved it, now Lem is getting me one. Highly recommended!!
Old 08-21-2005, 01:59 PM
thanks for the input purduefarmboy460...........i've heard alot of good things about edge.
Old 11-06-2005, 01:57 PM
Gear Jammer Gear Jammer is offline
Send a message via AIM to Gear Jammer
I use to have a 96 7.3 and i put a 3.5in down pipe on it and cut the muffler off and replaced it with a stright pipe and it sounded good and i allso had a k&n intake on it. I like the sound of the 7.3 better then the 6.0 it sounds more beastly. Good luck and that is one hell of a motor.
Old 11-11-2005, 10:38 AM
you just put the bigger downpipe and got rid of the muffer.....did you notice any power increase or just the sound....was there a reason that you didn't go with bigger pipe all the way out?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
