injector's - Ford Powerstroke Diesel Forum
post #1 of 17 Old 09-29-2013, 07:20 PM Thread Starter
quicknick106z's Avatar
injector's
what should i do need new one's and want alittle more then stock.
96 ford f250 7.3 edge evo straight pipe (Blown up Junk
quicknick106z is offline
post #2 of 17 Old 09-29-2013, 08:34 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Rosewood or ac codes, how much do you want? Also baby swamps, those are some that are just a little over stock, rosewood makes them much larger tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 17 Old 09-30-2013, 04:55 PM
CSIPSD's Avatar
What's your budget? HP goal?
I would contact Performance Injection Systems. Talk to Tim. No better guy in the business.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #4 of 17 Old 09-30-2013, 06:17 PM Thread Starter
around 300 stock? its so slow right now like if you hold it to the floor stock it goes to 2500rpm and starts poping and rolling white smoke?. looked at stage one rose are 500.00$
post #5 of 17 Old 09-30-2013, 07:18 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
His budget built are $500, premium is a tad higher for new, how many miles you have now?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 17 Old 09-30-2013, 08:32 PM
CSIPSD's Avatar
Stock obs truck has about 190hp to the rear wheels...
If you want 300hp then a set of 160/30 or 160/100's would get you there.
Would need to look at an electric fuel pump at that point.
Joe
CSIPSD is offline
post #7 of 17 Old 10-05-2013, 08:56 AM
Nonturbo's Avatar
Quoted: 4 Post(s)
Just gonna kind of jump on this thread instead of starting a new one. With the mods in my sig would it be better just to get stage 2's and have my chip tuned down for them? From rosewood its the same price so is there any reason not to get the bigger ones?
Austin
1997 f250: mbrp 3in downpipe 4in side dump exhaust, diy 6637 intake, TW custom tuned 6pos chip, wicked wheel 2, rough country 4in lift, dana 60 swap, led dash lights, explorer overhead console, LED tail lights, dual trans coolers, SD fog lights, 08 rear diff cover, diy efuel, 20" racleline wheels with 35" firestone destination mt's,lots more little things
Nonturbo is offline
post #8 of 17 Old 10-05-2013, 12:16 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Yes get the two's you may want more power later down the road, but your going to want to upgrade your hpop as well
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 17 Old 10-05-2013, 12:25 PM
CSIPSD's Avatar
Depends on what your getting... again this is why I hate this stage 2 stage 5 crap...
What kind of injectors are you getting?
A 160/100 can use less hpo for the same HP then a 160/0... simply because you can shorten the PW...
Stop using stage bla bla black and say what your getting.
Joe
CSIPSD is offline
post #10 of 17 Old 10-05-2013, 12:52 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
He said rosewood, on his site it lists them as 160/80
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
