Turbo fluttering - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-25-2013, 08:27 PM Thread Starter
doyle95's Avatar
Turbo fluttering
So today I got my baby swamps installed I absolutely love them but I'm having two issues.
1. Check engine light under heavy throttle after a couple seconds and then it'll go out after I shut the truck off I'm assuming it has something to do with the hpop would this be the right direction to look?
2. And also when I get up pass 28 psi of boost it sounds like my turbo has a flutter anythoughts on this or is this common at those levels?
Thanks for your help guys
1995 FORD F-250
4in straight pipe
AFE Stage 2 Intake
FPR shim PHP Chip
Plans for truck
rosewood stage 2 budget built injectors
John woods race tranny
D66 Turbo
E-Fuel
6.0 Intercooler
6in lift in front on 4in lift in rear
20x12 fuel octane deep chrome
For sale
Stock Air Box off Obs with K&n air filter
Factory Spare tire more to come soon as i will be looking for a 6.0 here pretty quik if interested pm me
doyle95 is offline
post #2 of 9 Old 09-25-2013, 08:32 PM
Gaius's Avatar
Quoted: 50 Post(s)
Could it be defueling? I've heard of some OBS's doing this around 26-28 psi.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #3 of 9 Old 09-25-2013, 08:39 PM Thread Starter
doyle95's Avatar
It's like a fast fluttering and the faster I got the faster it gets it's weird it doesn't feel like its defueling
1995 FORD F-250
4in straight pipe
AFE Stage 2 Intake
FPR shim PHP Chip
Plans for truck
D66 Turbo
E-Fuel
6.0 Intercooler
For sale
doyle95 is offline
post #4 of 9 Old 09-26-2013, 05:59 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Check it for shaft play, and if your hpop is stock you probably have low psi for those sticks, I had that problem with stock sticks but mine were split shots
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 9 Old 09-26-2013, 07:25 AM Thread Starter
doyle95's Avatar
That's what I was thinking on the hpop I've been talking to joey from terminator engineering about a T-500 are those good pumps I've heard from a couple people that those are better than the srps and also if I am in need of a turbo any suggestion I was thinking about the barder 66 diy kit but any other suggestions
1995 FORD F-250
4in straight pipe
AFE Stage 2 Intake
FPR shim PHP Chip
Plans for truck
D66 Turbo
E-Fuel
6.0 Intercooler
For sale
doyle95 is offline
post #6 of 9 Old 09-26-2013, 07:43 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
The DIY 66 I've heard is good, so is the d66, t500 I've heard good things about but not as good as the srp1.1
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 9 Old 09-26-2013, 09:45 AM Thread Starter
doyle95's Avatar
Ok how hard are these turbos to rebuild?
1995 FORD F-250
4in straight pipe
AFE Stage 2 Intake
FPR shim PHP Chip
Plans for truck
D66 Turbo
E-Fuel
6.0 Intercooler
For sale
doyle95 is offline
post #8 of 9 Old 09-27-2013, 01:52 PM Thread Starter
doyle95's Avatar
Also another thing I noticed with the turbo fluttering is my gauge is fluttering also if that helps at all
1995 FORD F-250
4in straight pipe
AFE Stage 2 Intake
FPR shim PHP Chip
Plans for truck
D66 Turbo
E-Fuel
6.0 Intercooler
For sale
doyle95 is offline
post #9 of 9 Old 10-08-2013, 07:59 PM
NorcalPSD925's Avatar
mine defueled around 32+.
i have a dieselsite relief valve now and works great.
96 7.3L, RCSB, Race truck
Only regular cab short bed OBS in Nor Cal!
NorcalPSD925 is offline
