Western Plow GPR Relay - Ford Powerstroke Diesel Forum
post #1 of 50 Old 09-25-2013, 10:27 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Well going against the grain of everyone on the Stancor bandwagon I figured id try the Western Plow relay and i got it installed last night and all in all im impressed. Ive been having a mild loping start issue on my OBS since ive gotten in and i figured id replace the GPR regardless and it didnt fix it totally but it seems to have helped a bit i think i have some bad GPs. Its definitely better than the stock GPR that was in there. So time will tell how well it lasts through the winter.
Heres a link where i got mime http://gotplowparts.com/i-7281767-we...le-56131k.html
Heres a comparison between the two.
I just mounted it at the stock location, only was able to use one of the holes since the new relay is bigger but i think it will hold just fine
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 50 Old 09-25-2013, 01:36 PM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
I'm sure you know this but any lopping wont be caused by gp's they ONLY help it start.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 50 Old 09-25-2013, 02:03 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
At start up it will because if its not hot enough not all the cylinders wont fire until it get hot enough to fire thus white smoke on start up
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 50 Old 09-25-2013, 02:21 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
I am right with you on the Western relay. It has a 100% duty cycle And is $12. I have yet to replace a western relay, because they just Never go bad
Unlike the stancore one that is $50+ and doesnt have a 100% duty cycle
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 50 Old 09-25-2013, 03:34 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Agreed ^, Brad turned me onto them a year ago.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #6 of 50 Old 09-25-2013, 03:44 PM
Gaius's Avatar
Quoted: 43 Post(s)
Nice, never heard of the option.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #7 of 50 Old 09-25-2013, 05:53 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
And hell even if it only lasts 2 years im way out ahead with $12 vs $50+ for the stancor.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 50 Old 09-25-2013, 06:10 PM
OL' OutLaw's Avatar
here's the one I've been using... the points slide against each other and are Self-Cleaning....
supposedly they last a Very long time....and now, I control when, ( and, or even if ),
it comes on....
mine's been in for two yeatrs now, and works perfectly... :
Ford Diesel Glow Plug Relay Manual Controller Solenoid | eBay
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #9 of 50 Old 09-25-2013, 06:22 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
it comes on....
You do realize you could just wire up a manual override by just connecting the positive switch side to a switch
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #10 of 50 Old 09-25-2013, 06:38 PM
Quoted: 787 Post(s)
Your welcome Pat. : :thumbup:
Corey@CNCFAB is offline
