affordable mechanical 7.3 - Ford Powerstroke Diesel Forum
post #1 of 26 Old 09-18-2013, 11:41 AM Thread Starter
Hey guys, this is my first post and ive got a few out of the box questions for ya. I am mid build on my new longblock for my 1996 f250. My plans are to get everything done now that is not accessible with the engine in the truck, and run stock until i get some more $$$$. My question is about the possibility of an affordable mechanical injection system. What i was thinking is instead of getting an entire front cover made, why not make a new top piece for the existing hpop tower that can hold a correctly sized gear for running a mechanical ip. The problem with this would be that the new gear would be turning the wrong direction, correct? To get around this, would it be possible to place the ip in front of the engine instead of in the valley of the engine, hence the pump SHOULD be turning the correct way. just a little food for thought and any help will be greatly appreciated.
Pstroker4life is offline
post #2 of 26 Old 09-18-2013, 06:00 PM
erics diesel's Avatar
Just look up e fuel conversions that people have done it uses an electric pump so no need for a mechanical one
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 26 Old 09-18-2013, 06:24 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
he means mechanical injection pump. i'm guessing along the lines of the p pumped hypermax conversion
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 26 Old 09-18-2013, 06:51 PM
CSIPSD's Avatar
Affordable mechanical 7.3...
7.3 IDI...
There is your answer.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 26 Old 09-18-2013, 07:03 PM
the baconator
Quoted: 143 Post(s)
7.3 IDI...
that is a smart *** answer
post #6 of 26 Old 09-18-2013, 07:16 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
smart azz yes, accurate also yes
There is no cheap way to do this. I am not sure what you mean by affordable but you will have 10 grand into it done right
Trucks and parts............
kanuck15 is offline
post #7 of 26 Old 09-18-2013, 07:19 PM
the baconator
Quoted: 143 Post(s)
i don't think 10 grand will come close i think 30K will
post #8 of 26 Old 09-18-2013, 07:22 PM
kanuck15's Avatar
Quoted: 10 Post(s)
The hypermax kit is 16k. Assuming they make a profit on it and doing it yourself you dont use top notch parts you could keep it in 4 digits. Depends on the injection pump. If you even think the word Sigma pump its a 30k venture but a used bosch pump wouldnt be bad
kanuck15 is offline
post #9 of 26 Old 09-18-2013, 07:28 PM
the baconator
Quoted: 143 Post(s)
well doing it right requires top notch parts (in my book). i have also that getting a kit is sometimes easier than piecing things together. but you're right in how much work are "you" willing to do
post #10 of 26 Old 09-18-2013, 07:31 PM
kanuck15's Avatar
Quoted: 10 Post(s)
The machining of the front cover is the most labor intensive. Also the adapters to run cummins injectors in our heads. Fabbing up some lines and new valve covers arent bad.
Hypermax - Product Display
they break it down pretty well but some of those prices are jacked
kanuck15 is offline
Tags
7.3 , mechanical , performance , powerstroke
