Ts chip - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-15-2013, 08:12 PM Thread Starter
Ts chip
I just bought a TS chip for my 7.3 and was wondering if I would notice any difference in power/driveability compard to the Edge evo CS that I have been using? Also wondering since I have no pillar gauges if I could use my CS to monitor my my boost egt's ect. It would really suck to buy gauges since I already have my CS to monitor temps ect. Also my truck is a 5spd. Thanks
nwatson is offline
post #2 of 14 Old 09-15-2013, 08:24 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
As long as the egt probe is not in down pipe, you should be fine, not sure on power differences in the ts vs edge, especially if you only got canned tunes
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 14 Old 09-15-2013, 09:40 PM Thread Starter
Yeah it's drilled into the manifold and I went with the canned tunes. I didn't think there was a point getting custom tunes since all I have are turbo back exhaust and tymar intake. It seemed that most of the custom tunes were mostly for the auto trans shift points and stuff.
nwatson is offline
post #4 of 14 Old 09-15-2013, 10:46 PM Thread Starter
Any one else know if I would be expecting any power difference?
nwatson is offline
post #5 of 14 Old 09-16-2013, 07:26 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Honestly even tho your stick it would still have more power with custom tuning
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 14 Old 09-16-2013, 11:03 AM
My truck came with an edge box, i threw that away and installed a stock tuned TS, i am running a DP/exhaust and intake as far as mods and the difference was huge. More power and i noticed a huge improvment over how well the truck ran, quieter smoother idle etc. I threw in an edge CS for gauges so I have the best of both worlds.
matt-jenkins is offline
post #7 of 14 Old 09-16-2013, 11:24 AM Thread Starter
Yeah I don't like how on my edge cs I can only really run on stock or extreme. On tow which they claim is 40hp my truck feels slower than stock. On street which is 60hp it runs good but drives like **** unless I drive like a granny it feels really jerky. And on extreme the power is decent and drive good but I noticed the engine is a lot louder compared to stock. Does the ts make the engine a lot louder like the edge cs does?
nwatson is offline
post #8 of 14 Old 09-16-2013, 11:27 AM
Nope, i can go between all settings and the idle remains unchanged and so does the motor noise all through the powerband, I find the throttle still sensitive(apparently its just an OBS thing) but not as bad as on extreme with the Evolution. Just be aware that the 100/140HP tunes you dont really get much of a gain from them since we are limited by our stock injectors.
post #9 of 14 Old 09-16-2013, 11:30 AM Thread Starter
Ok sweet. I can't wait to get my ts chip. Are there any tips or tricks on installing it?
nwatson is offline
post #10 of 14 Old 09-16-2013, 11:32 AM
its 10x easier to pull the computer right out of the truck rather then trying to clean the contacts from inside the cab, make sure you get the contacts clean. dont rush and do a half assed job getting the contacts bare. i lucked out and got mine perfect on the first try.
