MBRP Downpipe Noisy? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-10-2013, 06:02 PM Thread Starter
How much in cab noise does swapping to a new downpipe add? My cab is unbearably loud now. Just wondering how much the noise goes up, or if something is wrong.
Kingpimp is offline
post #2 of 13 Old 09-10-2013, 06:37 PM
Arcturus's Avatar
Make sure it isn't touching the firewall anywhere.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #3 of 13 Old 09-10-2013, 07:10 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
You may wanna put dyno mat or something similar on the pass side floor
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 13 Old 09-10-2013, 07:15 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
I would bet money the DP is rubbing somewhere. My MBRP pipe fit like C R A P
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #5 of 13 Old 09-10-2013, 07:25 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Mine fit great
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 13 Old 09-10-2013, 08:07 PM
BR'sCrewCab's Avatar
Mine was rubbing and I thought my turbo was going out.
96 F250 Crew Cab XLT
125,000 miles, Full Force Stage 1 Injectors, 4:10 rear, Dana 60 Swap, F350 Rear Lift Blocks, 325/60R18, 3" Down Pipe, 4" Exhaust, Tymar Intake, Aeoroforce Interceptor, DP Tuner (no start, stock, high idle, drive thru, 80 Eco, 60 Eco, 60 tow, 120 hp Race Tune), 7.3 Intercooler, 2.25 PMF RSK, V-Code Front Springs, B Code Rear Springs, Complete Alpine Audio System Upgrade, Tru-Cool Trans Cooler, Pro Comp 1069 18x9 Rims, John Woods Tow Master Transmission, Air Lift Air Bags
BR'sCrewCab is offline
post #7 of 13 Old 09-11-2013, 01:50 AM Thread Starter
Are you guys tearing out the heat shield on the lower half of the pipe? It seems to rub a bit there. Or rather the clearance is very tight and I think when the engine rocks from startup or torquing, it actually comes in contact with the heat shield.
Kingpimp is offline
post #8 of 13 Old 09-11-2013, 04:32 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
On the stock down pipe?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 13 Old 09-11-2013, 07:37 AM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
Mine is pretty quiet, the pipe fits well, the only noise I had was when it was hitting the firewall, but after massaging it , the engine is actually a little quieter with the mbrp pipe and exhaust.
dirtcrew51m is offline
post #10 of 13 Old 09-11-2013, 09:47 PM Thread Starter
That's what it is: rubbing against the cab. I took it all apart, bent the cab back, put it together 3 more times, cut an inch off the downpipe, and it still makes noise when in reverse and during some highway cruising.
This MBRP downpipe sucks dick. First and last time I order something from them. Going to take it apart again one more time before I order a new one.
Kingpimp is offline
