Quick E-fuel question... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-06-2013, 06:49 PM Thread Starter
Gaius's Avatar
Quoted: 41 Post(s)
I'm putting together ideas for E-fuel, and I'm wondering why more people don't use the stock supply lines at the heads? I'm thinking you could cut it off the "Y" at the pump, and flare or even use a compression fitting on them.
I also see people cut off the stock 90 degree fittings at the head. Are these an odd thread/fitting?
Thoughts?
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #2 of 5 Old 09-06-2013, 07:05 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
Its just cleaner to use different lines, A lot of guys unbolt the pump and use an adapter to reuse the lines into the heads. I know the heads are threaded 1/8th npt.
I am going to be doing E fuel this weekend probably. I plan on doing just what you said. cutting the stock lines to use them how I want. Although I am probably just going to double clamp them and call it good till next time the turbo is out
Trucks and parts............
kanuck15 is offline
post #3 of 5 Old 09-06-2013, 07:52 PM Thread Starter
Gaius's Avatar
Quoted: 41 Post(s)
Sure would save to have to pull the pedestal and up-pipe collector, too.
I would put a quick flare on the end of the line where you cut would be best. And one clamp would be enough, just make sure you use fuel injection clamps. I did this on the fuel system in my Fuel Injected Grand Wagoneer.
05 F350 Crewcab
Gaius is offline
post #4 of 5 Old 09-06-2013, 08:07 PM
kanuck15's Avatar
Quoted: 10 Post(s)
the double clamp does fine, done it plenty of times. I just had the turbo out and a day later my fuel pump started leaking. If I pull my up pipes I will be putting bellowed ones in and thats not in the cards right now
kanuck15 is offline
post #5 of 5 Old 09-08-2013, 04:08 PM
m j
and they are an odd fitting, vibra lok
Parker - VIBRA-LOK
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
