New trubo and check engine light - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-01-2013, 08:17 AM Thread Starter
Toddmichaud's Avatar
I just installed a beans d66 in my 95 f-250 along with the actuator and butterfly delete mods. When I get on it, the service engine light comes on almost as if im over boosting but the light will remain on untill I shut the truck off. The truck also is very underpowered while this light is on also as if overboosting and defueling but to my understanding if the turbo were over boosting the light would go off after a few minutes. Any suggestions on what the problem could be?
Thank you for your time,
Todd
Toddmichaud is offline
post #2 of 9 Old 09-01-2013, 08:38 AM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
scan it to find out for sure, but my guess is low ICP
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 9 Old 09-01-2013, 09:22 AM Thread Starter
How would you go about correcting low icp?
post #4 of 9 Old 09-01-2013, 09:24 AM
the baconator
Quoted: 146 Post(s)
either your ICP sensor is bad or your HPOP is weak. you need to scan it to see what the code is.
post #5 of 9 Old 09-01-2013, 09:25 AM Thread Starter
ok thanks when I get home from work ill scan it and get back to you, thanks
post #6 of 9 Old 09-01-2013, 03:10 PM Thread Starter
Ok well I'm home now and i've learned that my generic scanner will not scan my truck. I will have to go to the ford dealer on tuesday to get the codes
post #7 of 9 Old 09-01-2013, 03:20 PM
the baconator
Quoted: 146 Post(s)
no a generic scanner will not work. lots of people use AE (auto enginuity) or a snap on mt2500(brick). i have used a snap on brick but now i use a snap on solus, belonsg to a friend. also DP tuner makes the infinity which works as well. ford will probably charge you the diagnostic fee to read the codes however much that is
post #8 of 9 Old 09-01-2013, 03:41 PM Thread Starter
Ok thanks I have access to the snap on scanner at my school so i might wait on that, Thanks
post #9 of 9 Old 09-02-2013, 11:36 AM
Off topic for a second, does the Solus need any keys like the K2A to talk to our OBS?
Haulstroker is offline
