I/C pipe help - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-31-2013, 09:34 AM Thread Starter
stroken96's Avatar
Exclamation I/C pipe help
So i have my I/C mounted and truck back together but i am having problems with the pipes to the spyder. I was wondering if anyone has used the stock pipes off a 7.3 with little modification to them of if i need to chop them up and make a custom set. I would like to do it all DIY instead of buying the kit as to keeping it a low buget build. Thanks
stroken96 is offline
post #2 of 7 Old 08-31-2013, 01:01 PM
JSchuricht's Avatar
Many people have used the SD pipes by either extending the pipe or using a longer boot on the driver side.
JSchuricht is offline
post #3 of 7 Old 08-31-2013, 01:24 PM
Quoted: 85 Post(s)
Feedback Score: 4 reviews
I use the superduty pipes. I lengthen both pipes at the intercooler end by 3" and the hot side pipe I heat the large 90* bend and remove about 5* of bend. Doing this makes for a perfect fit and allows use of the stock boots.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #4 of 7 Old 08-31-2013, 08:45 PM Thread Starter
stroken96's Avatar
Ok, so by heating the 90 what did you do there?
post #5 of 7 Old 08-31-2013, 08:48 PM Thread Starter
stroken96's Avatar
As in did you bend it with just a hand pipe bender or did you use a exhaust bender?
post #6 of 7 Old 09-01-2013, 06:36 AM
Quoted: 85 Post(s)
I clamp the pipe in a vise near the small bend, heat the whole larger bend with a rosebud, and use a 2" piece of pipe to pry some of the bend out of the large bend. What this does is give some clearance between the intercooler pipe and the ac compressor otherwise it is rubbing on the compressor pretty hard and makes it difficult to line up the pipe to the spyder.
Jack
322000 miles
post #7 of 7 Old 09-01-2013, 09:27 PM Thread Starter
stroken96's Avatar
10-4 Thanks for the info guys.
