Bellowed Up Pipes - Ford Powerstroke Diesel Forum
post #1 of 36 Old 08-30-2013, 08:01 PM Thread Starter
Diesel_brad's Avatar
Quoted: 4 Post(s)
Bellowed Up Pipes
Just incase anyone is looking for some, with out the $800 price tag.
I needed to do something with my leaking up pipes while I had the turbo out and trying to find something other then the IH $800 took me some looking.
I found a couple options....
Whites Diesel.
All new stainless One piece
$450 shipped
EDIT
Just a FYI about the "whites diesel" Up pipes. They are NOT theirs, They are made by Irate.
I happen to be going thru my cardboard boxes and seen an Irate packing slip. The I put 2 and 2 together. My pipes did not come in time(like whites said) because Jake(@ Irate) had to make them.
Whited marked them up at least $25 and had Jake drop ship them after had made them.
Save yourself the headaches and just get them from Irate
Irate
$425
Bar None Diesel
Recycled factory pipe w bellows added and no more donut, now uses gasket
$435
Rosewood
(I think they are just like Bar none)
$200
I went with the Whites Diesel ones. Very nice piece
I did NOT use the supplied hardware. it was JUNK. I reused my studs/bolts from the collector and had New Ford hardware for the pipe/manifold
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #2 of 36 Old 08-30-2013, 08:34 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Thanks brad, but rosewood seems the cheapest tho, why not go with him? Other than the new 1 peice part? And what kind of gaskets?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 36 Old 08-31-2013, 04:17 AM Thread Starter
Quoted: 4 Post(s)
I am not sure how Jim builds his. If it is all one piece or if he welds the flanges to the pipe then uses a gasket to seal it to the collector.
I would of considered Jims pipes, but I had already ordered the Whites ones,
ANOTHER reason for this list, so people actually see what their options are
post #4 of 36 Old 08-31-2013, 06:11 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
I have a set of the bar none diesel ones on the way to me. Im doing a write-up on them when I do the install in a couple of weeks
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #5 of 36 Old 08-31-2013, 06:33 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
I think Rosewood welds the pipes to the factory collector. Where as yours are all new and no collector at all. I'd imagine yours may flow a little better then a stock setup
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #6 of 36 Old 08-31-2013, 08:08 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Those new stainless ones do look really good tho
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 36 Old 08-31-2013, 10:41 AM
Doesn't Even Care
Quoted: 69 Post(s)
Yeah, they do look good. How are you supposed to get them in since they are all one piece? You'll never get them under the cowl and down by the firewall.
Nick
"The Mistress"
post #8 of 36 Old 08-31-2013, 11:42 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Trams removal, or lift the cab
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 36 Old 08-31-2013, 09:19 PM Thread Starter
Quoted: 4 Post(s)
They make 2 piece ones for the SD already
I am talking for OBS without spending $800 on the IH ones
post #10 of 36 Old 08-31-2013, 09:33 PM
I used the Irate diesel stainless up pipes. Remove turbo and downpipe. Two guys can work in from the top. Have to coax the drivers side a little with a pry bar against the cab lip. Popped right in about 15 minutes. One guy underside of truck and one guy on top. Coordination between the two people worked well for me. Everything bolted back up perfectly.
ToddM715 is offline
