Strictly diesel gauge wiring kit and fuel pump wiring kit - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-29-2013, 01:53 PM Thread Starter
doyle95's Avatar
I just got these they seem very well put together and a great quality. So I just have a couple of questions about these 2 kits. As for the gauge kit I was wondering witch wire I need to tap into for the illumination and if I should just wire nut all the the illumination wire to gather and all the powers together? And what should I tap my constant power into?
& as for the fuel pump kit where should I plug my oil pressure sending unit into is there a predrilled hole in the block and what should I tap in to for my low amp circuit for my relay for the fuel pump
Thanks a ton guys :thumbup::
1995 FORD F-250
4in straight pipe
AFE Stage 2 Intake
FPR shim PHP Chip
Plans for truck
rosewood stage 2 budget built injectors
John woods race tranny
D66 Turbo
E-Fuel
6.0 Intercooler
6in lift in front on 4in lift in rear
20x12 fuel octane deep chrome
For sale
Stock Air Box off Obs with K&n air filter
Factory Spare tire more to come soon as i will be looking for a 6.0 here pretty quik if interested pm me
doyle95 is offline
post #2 of 3 Old 08-30-2013, 03:37 PM
Sam Burton's Avatar
don't use wire nuts on a truck those are for house wiring.
you can connect the light power wires together and i connected mine to the headlight switch so they would dim with the interior lights.
there is a port on the oil filter adaptor you can use for the sending unit.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #3 of 3 Old 03-11-2015, 10:51 AM
lugnut1009's Avatar
Quoted: 8 Post(s)
Did you get your gauges all wired in? I just bought a set a while ago and haven't gotten to installing them yet.
SOLD (AND SORELY MISSED):1996 F250 CC SB ZF5 4WD
9000LB Ramsey winch, 3" dp, straight exhaust, superchips mini max, 6637 filter,
4" Superlift, 315/75 Toyo MT's, custom step bars
2011 F150 CC 2wd with V6 Eco-boost
factory twin turbo and intercooler, 365 hp and 420 ft/lb torque
lugnut1009 is offline
