Rebuilding a 7.3 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-28-2013, 12:59 PM Thread Starter
FreightShaker244's Avatar
Rebuilding a 7.3
Just wondering on cost at machine shop. I want to build a 7.3 powerstroke but few machine shops I called it seems cheaper just to but a long block already done.
Heads $495 each plus parts
$235 line hone
$35 cylinder hole
$225 to do crank
$135 plus parts for frost plugs n cam barrings
$185 just to inspect
Your gonna be $2000 at the machine shop alone. Just wondering if that seams realistic . I've sent big cummins and cat engines to the shop for $1500 .
What have others done that rebuilt their own engines. I'm talking block n heads n crank. Not asking bout injectors ect
Sent from AutoGuide.com App
1995 F-250 7.3 Powerstroke 5 Speed, 6'' Lift. DIY Intake/Napa filter, 4" exhaust.
FreightShaker244 is offline
post #2 of 7 Old 09-01-2013, 06:26 PM
Depending on what your wanting done i had my all work done for right around 1200 bucks
Heads an block cleaned an checked
Valve job with All new valves and comp 910 springs with a little porting
.030 over on block, piston pins sized
Polished crank
And all mating surfaces checked for flatness
96 F-250 ext. cab long box 4x4
Intake, auto meter(oil psi, tranny,boost, EGT) IDM mod, .030 over rebuilt motor, comp 910's, BDP d66 turbo, BDP stage one injectors, BDP fuel system, t500, BDP custom tuned 6pos, coolingmist water/meth, 3in downpipe 4in duals, dana 60 swap, 203* t-stat
traction bars, 6.0 intercooler
furture plans,
BTS, 300/200 sticks, studs, pushrods, t4 mount, NEW PAINT
GOAL= 600+ hp
stroked out is offline
post #3 of 7 Old 09-01-2013, 06:36 PM Thread Starter
Thanks for the reply. That's pretty much what I want done, magnaflux the block, flatten all surfaces, and valve job. The shop was jus giving me quote for it all and seemed way too much money. But thanks for the ball park idea on price.
post #4 of 7 Old 09-03-2013, 05:23 AM
No problem, if the shop doesn't have a tool to remove and replace the injector cups rosewood use to rent a tool to do it im not sure if he still does that anymore.
How much power you Looking to build it for?
furture plans,
GOAL= 600+ hp
post #5 of 7 Old 09-03-2013, 05:30 AM Thread Starter
I've built lots of dt466e and 7.3 idi's - assembled from ground up but didn't deal with the paying for machine work- work paid for it. So I'm fully confident I can get it done myself. I'd like to see around 350 to 375hp to the ground. Just enough power to throw u in the seat. Nothing crazy like people say they want 600hp and only have $4,000 to spend lol. Just want a fresh motor.
Had this truck and had to sell it due to losing job and now I found the current owner and sold it back to me now I'm in good position to keep and build it like the original plan. Rebuilding a 7.3-imageuploadedbyautoguide1378215037.171913.jpg
post #6 of 7 Old 09-03-2013, 12:54 PM
I see well at 350hp you wont have to worry about headstuds or a girdle
How much lift you got on that truck
furture plans,
GOAL= 600+ hp
post #7 of 7 Old 09-03-2013, 01:16 PM Thread Starter
The truck is a 95 got 3 inch body lift with a 4inch susp lift. Solid front d60 . I broke one of the rear axel shock mounting tabs off the axel so I'm looking into upgrading to possibility dual shocks (4 on axel) with trac bars but trac bars is after the motor (putting main focus onto motor first.
