rebuilding fuel system and turbo - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-25-2013, 03:13 PM Thread Starter
96coolbus's Avatar
here i am rippin some stuff off the bus and i run into a few issues i could use some guidance on.
short video below
cool bus fuel system, turbo overhaul - YouTube
the whole valley area was filled with rats nest ****, bones, debris, etc from sittin wherever it sat before i picked it up. and it was all soaked in diesel so i decide to pull all this stuff off and rebuild it.
the fuel line goin off to regulator broke a peice of the regulator off, you can see it in the vid.
and the turbo seals, bearings, copper bushings etc are done. that compressor wheel is chewed up.
what can i do about the regulator? i cant seem to find one unless its the whole bowl assembly-$350-dieselorings.com
plus a new pump, hoses, clamps, etc im lookin 5-600 for the fuel system. do you think thats worth it or should i just do electric?
turbo rebuild from dieselorings would run me around 250 with the 99up upgraded wheel. is that the route i should go?
96 E350 Cool Bus 7.3 - party bus, minor mods
92 Mustang LX 5.0 - minor mods 13.9@99.5
87 Astro 4.3 - the workhorse... lol
97 Escort Wagon - Turboed, project on backburner
96coolbus is offline
post #2 of 10 Old 08-25-2013, 08:47 PM Thread Starter
96coolbus's Avatar
so i found a new bowl asembly and pump somewhere else at a more reasonable price. but im still thinkin of gettin my turbo rebuild products from deiselorings.com but im not sure about one thing.
the compressor wheel i should order.
here is a link to the stock 94-98
#9-009 - 94-97 TP-38 Compressor Wheel - Turbo and Related Items - 1994-1998 Ford 7.3L
here is a link to the 99-03 one
#14-070 Garrett TP-38 / GTP-38 Compressor Wheel
and the whislin wheel
Whistlin' Wheel 94-03 Compressor Wheel
so whats gonna be the difference really? anyone got direct experience?
post #3 of 10 Old 08-26-2013, 06:22 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Do e-fuel.. As for the wheel upgrade, just do a stock wheel or a whicked wheel 2. Don't bother with the 99-03 wheels and the upgraded wheel for those years is the stock 94-97 wheel also know as a whicked wheel 1
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #4 of 10 Old 08-27-2013, 06:38 AM Thread Starter
96coolbus's Avatar
i have already oredered the fuel system. just went with stock replacement stuff. decided it will be a faster reinstall than setin up electric. plus it was pretty inexpensive in comparison.
i will look for the wicked wheel 2. i have only found the first one i guess.
and i took all the bolts off compressor side of turbo, and im pretty sure it was rtv sealed to the plate... it wont come off even with some hammer influence.
dare i try pryin between the two pieces?
post #5 of 10 Old 08-27-2013, 06:49 AM Thread Starter
96coolbus's Avatar
so the wicked wheel 2 is over 200 and a stock wheel is 80 bucks. i might just get the 94-98 stocker
post #6 of 10 Old 08-27-2013, 08:21 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Is the turbo still mounted? On my obs there is an inaccessible bolt holding the housing just under the valve cover/behind it, but I just started taking the wheel out and the housing came off with it
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 10 Old 08-27-2013, 12:17 PM Thread Starter
96coolbus's Avatar
turbo is off the truck. i got a video up on the first post in this thread. and heres another with my current dilemmas
https://www.youtube.com/watch?v=N2tk_0F6G_c
post #8 of 10 Old 08-27-2013, 01:14 PM
ol_Blue97's Avatar
most guys cut all that stuff off and weld the oils passages shut.
FRANK THE TANK
post #9 of 10 Old 08-27-2013, 01:26 PM Thread Starter
96coolbus's Avatar
ya ive seen that. but the bolt cost me $1 and im sure ill figure somethin out for the sensor port and ive seen a few people go the route im goin.
just curious about the oil pressure issue
and scratchin my head at this compressor housing
post #10 of 10 Old 08-28-2013, 08:17 AM Thread Starter
96coolbus's Avatar
ebpv complete, need turbo assistance - YouTube
done with the ebpv delete. need help with turbo. watch the video if ya wanna help a dude out.
thanks guys
