Turbos - Ford Powerstroke Diesel Forum
post #1 of 22 Old 08-23-2013, 11:49 PM Thread Starter
Skaggzy's Avatar
Turbos
I was wondering what people are getting for boost on their turbos. my tuner was reads out 60's psi boosting when i am accelerating and i was wondering what the turbo is actually boosting. i havent put a set of gauges on it yet but i plan to and i just wanted to see what people with gauges say they are boosting to. oh and i have the stock garret turbo on it.
1997 F350 4x4 CCLB
7.3L Powerstroke
S&B high flow intake, 3" DP to 4" straight pipe, TS 6-position switch, Transmission Temp Gauge, Superlift traction bars, 315/75R16 Falkin Rocky Mountains, Leveling Kit, E-locker in rear
Skaggzy is offline
post #2 of 22 Old 08-24-2013, 05:21 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I hit 32-35 stock in the f-250 I had
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 22 Old 08-24-2013, 01:35 PM
NorcalPSD925's Avatar
same here.
96 7.3L, RCSB, Race truck
Only regular cab short bed OBS in Nor Cal!
NorcalPSD925 is offline
post #4 of 22 Old 08-24-2013, 04:53 PM
Quoted: 85 Post(s)
Before intercooler install with stock injectors about 28, after intercooler install stock injectors about 24, with stage one's and intercooler about 34 and these are all with a generic gold superchip. With a custom burned chip it should be slightly higher.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #5 of 22 Old 08-24-2013, 08:46 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Mine is a Cali model with 120cc split shots, as well as intercooled, with custom tunes
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 22 Old 08-25-2013, 10:07 AM Thread Starter
Skaggzy's Avatar
thats what i was thinking. for those that have installed intercoolers on their trucks. did you buy a kit or piece it together yourself? how much did the intercoolers help out? is it worth putting one in?
1997 F350 4x4 CCLB
7.3L Powerstroke
Skaggzy is offline
post #7 of 22 Old 08-25-2013, 10:57 AM
Gaius's Avatar
Quoted: 50 Post(s)
Stock turbo, pretty worn Federal injectors, Wildman tunes. I can get to 20 psi when it's cold out, 18 normally.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #8 of 22 Old 08-26-2013, 07:56 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
That's more like it...no way your seeing real #'s over that with a stock truck.
CT Performance, Inc. is offline
post #9 of 22 Old 08-26-2013, 08:35 AM
Sam Burton's Avatar
I am wondering about mine, stage ones, intercooled, 1.0 exhaust housing, Wildman tunes, and I am only hitting 25 psi max, very little smoke and only on the street setting, egts seem high too.
still need to get my 17* hpop in and move the map line to the hot side but it still seems low.
I have checked for exhaust leaks pre turbo and can't find any soot on the firewall.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #10 of 22 Old 08-26-2013, 12:09 PM
What are real numbers? 32-35 not real?
