96 7.3 NO START - Ford Powerstroke Diesel Forum
post #1 of 17 Old 08-14-2013, 11:20 AM Thread Starter
C_gullion's Avatar
96 7.3 NO START
Ok, so I drove the truck for a long time ran great put a chip on it and it ran great for awhile then started to get wts light and had to disconnect the battery cables to get to run then one day I went out and after it started it would fall on its face and die it would on run at wide open and it'd stay at low rpms then it finally died completely it blew smoke out when it done that and it hasn't done much since I've changed the pcm and still nothing the tach does move when cranking and it does crank over and got to start and run for about 10 seconds but shut back down afterwards but the oil gauge shows nothing so I checked oil and there was none in it so I put some in it and still no start I'm lost on this truck please help I've also checked fides and disconnected fuel bowl and still nothing please help!!
Corey
96 f250 eclb
Diy intake
Beans diesel 6 pos
4 inch rough country lift
3" diamond eye downpipe
6" mitre cut stack
Blackouts front back and top
Black and chrome hummer wheels
37" mickey Thompson baja claws
C_gullion is offline
post #2 of 17 Old 08-15-2013, 10:47 AM
Dirt rider1's Avatar
Um dude... Periods do help, and they ain't that hard to use...
Jordan
(dirt rider1)
1997 7.3 Powerstroke 2wd auto
Mods:
-Muffler cut off
-Cat. converter gutted and gone
-Diamond Eye 3" downpipe
-MBRP 4" exhaust (runs in front of rear wheel)
-Dodge Towing mirrors
-AFE high flow intake
-Real Tree seat covers
-Real Tree floor mats
-blacked-out headlights
-cab lights
-6 by 8' flatbed
-KC lights
-silencer ring removed
-17ton anchor shackle
Dirt rider1 is offline
post #3 of 17 Old 08-15-2013, 12:13 PM Thread Starter
C_gullion's Avatar
Sorry bout that, but with or without periods thats still my problem.
Corey
96 f250 eclb
Diy intake
Beans diesel 6 pos
6" mitre cut stack
post #4 of 17 Old 08-16-2013, 01:25 AM
CSIPSD's Avatar
Did you put "some" oil in it or did you fill it to the proper level?
Do you get a WTS light?
Do you have any SES lights on?
With the keys in your pocket, remove the chip... Then try and start again.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 17 Old 08-16-2013, 07:27 AM Thread Starter
C_gullion's Avatar
I put some oil back in I didn't fill all the way, I do get a wts start light. And no ses lights come on, I tried the cop but still got nothing acted like it wasn't getting fuel fuel bowl is filling up tho. I will fill it the rest of the way up with oil and try again
Corey
96 f250 eclb
Diy intake
Beans diesel 6 pos
6" mitre cut stack
post #6 of 17 Old 08-16-2013, 07:32 AM
CSIPSD's Avatar
Do you have gauges?
Joe
CSIPSD is offline
post #7 of 17 Old 08-16-2013, 07:41 AM Thread Starter
C_gullion's Avatar
Also the idm on my 5 speed truck was bad so I switched it with the one on this truck, will a 5 speed idm work with my auto truck or could that be some of the issue to?
Corey
96 f250 eclb
Diy intake
Beans diesel 6 pos
6" mitre cut stack
post #8 of 17 Old 08-16-2013, 07:42 AM Thread Starter
C_gullion's Avatar
And yes I have gauges, boost, egt, and trans temp.
Corey
96 f250 eclb
Diy intake
Beans diesel 6 pos
6" mitre cut stack
post #9 of 17 Old 08-16-2013, 08:11 AM
CSIPSD's Avatar
IDM is an IDM... no difference in them.
Joe
CSIPSD is offline
post #10 of 17 Old 08-16-2013, 08:28 AM Thread Starter
C_gullion's Avatar
Ok well it was bad when pulled off the other truck but it did start the other truck.
Corey
96 f250 eclb
Diy intake
Beans diesel 6 pos
6" mitre cut stack
