140V IDM mod resistor question - Ford Powerstroke Diesel Forum
post #1 of 44 Old 08-12-2013, 09:08 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Hey guys im considering the 140V mod for the 3 IDMs i have (1 IDM100V and 2 IDM120V) and i know the 100V and 110V require 75K 1/2W resistors, question is i have a bunch of leftover resistors from another project but they are 75k 1/4W resistors. Could i wire them in parallel to obtain a 75k 1/2W resistor? Only reason is i dont want to have to order a million more because they generally come in big packs and just wanted to use what i had if i could, if not oh well
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 44 Old 08-12-2013, 12:00 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
No, two 75 ohm resistors wired in parallel will give you a resistance of 37.5 ohms. Cheers!
Patrick Feeley is online now
post #3 of 44 Old 08-12-2013, 12:03 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Ahh now what about 2 150 ohm resistors?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 44 Old 08-12-2013, 07:00 PM
Quoted: 13 Post(s)
That would theoretically work (not that I would go that route). Cheers!
post #5 of 44 Old 08-12-2013, 07:32 PM
Quoted: 82 Post(s)
Feedback Score: 4 reviews
I get mine here 5 x 1 2 Watt 1 Metal Film Resistors from USA 75K Ohm | eBay , pack of 5 and cheap. I'm pretty sure he also has the one's you need for the 120v idm.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #6 of 44 Old 08-12-2013, 10:09 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
How did they work for you? any problems? and the 120V idm requires the 73.5k ones
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #7 of 44 Old 08-13-2013, 03:56 AM
Quoted: 82 Post(s)
I modified mine about two years ago, been working perfect. I've modded three others since then for other guys and they have had no problems.
Jack
322000 miles
post #8 of 44 Old 08-13-2013, 04:11 AM
CSIPSD's Avatar
Just to be clear... There is ONE... Repeat ONE voltage IDM... The part numbers are just that, part numbers.
You can call up Swamps to verify this if you like, however it is fact.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #9 of 44 Old 08-13-2013, 04:14 AM
CSIPSD's Avatar
To add to this, if you really want to do it right you want to do the HFHV IDM from Swamps diesel.
Doing a simple mod to an IDM is like adding a 10k resistor, sure you might get something out of it, but a chip is so much better.
Joe
CSIPSD is offline
post #10 of 44 Old 08-13-2013, 04:47 AM
Quoted: 82 Post(s)
From the factory there are three voltages 100,110, 120. I've also install a swamps idm and a diy 140v idm in the same truck and there was so little difference between the two that I'll just stick with the diy for penny's rather than the $150 one.
Jack
322000 miles
