Looking for more power, opinions? - Ford Powerstroke Diesel Forum
post #1 of 45 Old 08-10-2013, 10:19 AM Thread Starter
NorcalPSD925's Avatar
looking to spend around a G on some upgrades for my truck. its a 96 cali truck with AB's, ts chip with php tunes from KT, 3" dp, 5" exhaust, 6637 intake, ebpv delete
what would be worth doing?
-IDM mod (doing fersure)
-AD 140cc splits, worth doing for 10 more cc's?
-HPOP?
-e fuel?
-wicked wheel 2?
-D66? i get plenty of fuel to light it and still have light smoke at full boost (35psi) with 130cc ab's
-innercooler?
or?
96 7.3L, RCSB, Race truck
Only regular cab short bed OBS in Nor Cal!
NorcalPSD925 is offline
post #2 of 45 Old 08-10-2013, 07:54 PM
Quoted: 82 Post(s)
Feedback Score: 4 reviews
Go up to stage one single shots and get your chip reburned to run them or do Matt's (bigfuel) PCM repin. Intercooler if you tow often. IMHO the D66 is to big for stage I's unless you install a 1.0 exhaust housing on it. Hpop if your stock one isn't in good health. e-fuel if your stock pump is leaking or you just want to clear stuff out of the engine valley. I can't speak for the ww2 because I haven't tried it yet and would like to hear more positives from the people who are trying them.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 45 Old 08-11-2013, 06:36 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I have the same stuff but I would go DIY intercooler, and larger hpop (sd or terminator) and swamps idm for upgrades
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 45 Old 08-11-2013, 02:24 PM
doyle95's Avatar
What is this Matt's pcm repin you speak of?
1995 FORD F-250
4in straight pipe
AFE Stage 2 Intake
FPR shim PHP Chip
Plans for truck
rosewood stage 2 budget built injectors
John woods race tranny
D66 Turbo
E-Fuel
6.0 Intercooler
6in lift in front on 4in lift in rear
20x12 fuel octane deep chrome
For sale
Stock Air Box off Obs with K&n air filter
Factory Spare tire more to come soon as i will be looking for a 6.0 here pretty quik if interested pm me
doyle95 is offline
post #5 of 45 Old 08-11-2013, 02:56 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Look for Bigfuel, it's in his sig the link for the write up, it's re pinning the PCM harness and running the 49 state federal PCM for single shots instead of splits and more capable of running hybrids with an easier/better tune, or big singles
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 45 Old 08-11-2013, 05:58 PM
Quoted: 82 Post(s)
Here you go, Going from a '97 Cali MME2 to a '96 Federal NAW4
Jack
322000 miles
post #7 of 45 Old 08-11-2013, 06:54 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Thanks jack, I didn't feel like looking yet
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 45 Old 08-11-2013, 06:58 PM
gabegoforth's Avatar
With your current setup I would say intercooler. Your not going to see a lot of HP, but the cooler running engine will be worth it. Also you will see mileage increase.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #9 of 45 Old 08-12-2013, 09:14 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
FYI its a 20cc increase going to 99.5 SD's splits. You should plan on a modded HPOP as they are HPO hungry.
X2 on the IC.
CT Performance, Inc. is offline
post #10 of 45 Old 08-12-2013, 10:30 AM
Arcturus's Avatar
I thought that only 97 cali's had the AB injectors?
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
