Rosewood Stage 1 Injectors - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-08-2013, 03:15 PM Thread Starter
Ill be ordering stage 1 injectors in about a month or 2. Before I order them, I want to know everything else I need to upgrade. My tranny has about 95,xxx miles on it. I have a ts 6 position chip. Will i need a better HPOP? also do I need a bigger turbo? or would stock be okay for a couple months?
Djones21 is offline
post #2 of 2 Old 08-08-2013, 04:57 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
get a scanner and if your ICP and DC numbers are okay you can stick with your stock pump. if they are weak you should upgrade. E fuel is recommended, but again if you have good pressure you can run the stock system. rebuild the turbo. reburn your chip. and i would do 160/100s (stage 2s) because they are the same price and you can have them detuned and if you want more power you don't need new injectors
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
