Clutch and turbo help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-07-2013, 07:10 PM Thread Starter
So I just bought a 94.5 7.3 powerstroke as a parts truck to put into my 91 f350, I have everything apart and it looks like I will be needing a new turbo and clutch soon, I found a good deal on some 160cc 100% injectors and I wanted to know what turbo would be good with them and what clutch would hold up to them with normal daily driving and maybe 1 or 2 truck pulls a year. Also where do these engines normally leak oil from?
91psdf350 is offline
post #2 of 4 Old 08-08-2013, 05:03 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
oil leaks are common from the disptick where it meets the pan. the turbo pedistal, any number of o rings on the top side of the motor, and on the early PSDs like your 94 the inspection cover on the trans can rub through the back of the oil pan.
you can run a rebuilt stocker, a D66, and H2E, or get a T4 mount and run any number of turbos, i have 160/100s and a D66, w/ a 1.1 housing and a WW2. i find it laggy i am going to switch to a smaller 1.0 housing and see if that helps
for a clutch go bigger than you think you need. I have a Con O from southbend thinking that was all i would need. so far it is holding fine, however if i went with a Con OFE the first time around i could have saved some money. i will upgrade that when it needs it
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 4 Old 08-09-2013, 06:59 PM Thread Starter
I was gonna go with the con O rated for 350 horse 750 torque because that's all I can afford and I was going to wait on a turbo for a while, what kind of boost numbers are you getting and do u have a custom chip or anything ?
post #4 of 4 Old 08-09-2013, 08:47 PM
01Crewcab7.3's Avatar
I recommend an h2e or go t4.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
