Wicked Wheel 2 install and ebpv delete - Ford Powerstroke Diesel Forum
post #1 of 28 Old 08-01-2013, 07:51 PM Thread Starter
I will be pulling my turbo this weekend to install my turbo rebuild kit and ww2 and had some questions about the ebpv. I want to delete it but do i need to buy the delete pedestal or can it be done without? I am a novice welder but i have a buddy who tigs for a living.
1997 F350 SRW RCLB, 4.10s, RSK 4" on 37" Toyo M/T's, Tony Wildman 6 Pos., 3 Pillar Gauge Pod with Trans Temp, Boost and EGT's, BTS Valve Body, AFE Intake, 3" DP to 4" to Dual 6" Stacks, Custom Front Bumper, 12k Winch
Project 5 Speed soon to Come
s.hiles is offline
post #2 of 28 Old 08-02-2013, 09:21 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
You do not need a deleted pedestal. Honestly all I did was install a new oring in the actuator port washer and epoxied a pipe plug into the hole where the actuator rod comes out of. The extension port (where the EBPV butterfly is located) I pulled of, completely gutted, and capped the upper and lower ports that support the butterfly pivot shaft with freeze plugs and drilled holes above the plugs edge and inserted cotter pins to keep the exhaust pressure from pushing out the plugs. No leaks, no mess, no problem.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 28 Old 08-02-2013, 04:27 PM
Arcturus's Avatar
Hi Matt, you wouldn't happen to have any pics of that work would you? I got a downpipe on order and would like to do what you did or just wire it open while I got the downpipe off. I already pulled the plug on the EBPV. I just don't have the experience to follow along with what you are saying. All I know is that an o-ring or something back there can develop a bad leak.
Why use freeze plugs and cotter pins and not just epoxy or jb weld another pipe plug or even just tap it? Do you need to remove the turbo for what you did or is this extension port just bolted to it and accessible with the downpipe out of the way?
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #4 of 28 Old 08-02-2013, 04:30 PM
Sam Burton's Avatar
i did it the same way as bigfuel, I had my turbo off already so it was a snap but the EBPV housing does unbolt.
I am terrible about taking pictures though so I don't have any to show.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #5 of 28 Old 08-02-2013, 06:14 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
I'm in Lake Tahoe for a bacholur party. I can take a couple pics when I get back Sunday. If anyone else sees this Elmo had a great picture line-up when he delegated his.
Matt
'97
-Stage II trans.
BigFuel is offline
post #6 of 28 Old 08-06-2013, 04:10 PM
Red '97's Avatar
bump this thread. id also like to see those pics
-Conner
1997 F-250 Long Bed Extended Cab
--7.3 Powerstroke E40D Auto
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
-3 inch DP, 5 inch under truck, 6 inch Mitre!!
-2nd gen Wicked Wheel from Dieselsite
-Tony Wildman 6 Position Chip
Broke College Kid Mod
Now residing in LARAMIE, WY for school at the University of Wyoming! Hit me up if youre around, I'm always down for a hot rodding adventure
"Never cut what you can untie"
--Buckaroo Proverb
Red '97 is offline
post #7 of 28 Old 08-06-2013, 04:52 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Forgot all about it. Remind me in 2.5-3 hours.
Matt
'97
-Stage II trans.
BigFuel is offline
post #8 of 28 Old 08-06-2013, 07:59 PM
Well?
Rusty
rusty1161 is offline
post #9 of 28 Old 08-07-2013, 11:13 PM
Red '97's Avatar
forgot to check the thread lol hope you find some time to snap some soon
-Conner
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
--Buckaroo Proverb
Red '97 is offline
post #10 of 28 Old 08-08-2013, 08:26 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Yep, still forgot. I'm mostly on here in the mornings. Got lots of wedding stuff to do for my Cousin and I don't get home till after midnight after working 10 hours. My eyes are melting right now.
Matt
'97
-Stage II trans.
BigFuel is offline
