Added E-fuel and SD IDM any differences in performance? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-01-2013, 12:34 PM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I just wrapped up my e-fuel conversion and took it for a drive and i really dont notice any difference in performance, then i came back and parked and put in a SD IDM i got and then took it for another drive and still nothing. I know these really arent huge power mods but i would think i would have noticed SOMETHING different. Have you guys noticed any changes after these mods?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 5 Old 08-01-2013, 02:13 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
the mods you're doing are a benefit with bigger injectors and tuning. i noticed a difference after e fuel only because i went from 5psi fuel pressure to 65 psi. and it wasn't a huge difference
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 5 Old 08-01-2013, 02:19 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Yea i kinda knew it was a support mod more than anything performance but i guess i expected at least something.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #4 of 5 Old 08-01-2013, 07:37 PM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
You might notice something on the top end with the e-fuel, but there isn't a big difference between an OBS and SD IDM in stock form (higher voltage modded or the high frequency modded, then you would probably notice). Cheers!
Patrick Feeley is offline
post #5 of 5 Old 08-05-2013, 04:54 PM
I didn't use a SD IDM but I modded my own to be a 140V idm and I noticed a pretty big difference it was the best 23 cents I have ever spent
Ben
1995 Ford F-350 Centurion package
6637
3" Diamond Eye down pipe
4" back to 7" stack
PHP tuned 6 position chip
140V IDM Mod
Custom paint obsidian black/medium copper
Custom tow mirrors
95350PS is offline
