big turbo, intercooler setup questions - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-31-2013, 07:13 AM Thread Starter
6.9turbo's Avatar
Would this setup be good or bad for a stock '97 7.3? I was wondering if this would work, or if they'd even fit. These parts are on a 2000 T444E.
Thanks
ID:	148602   Click image for larger version
ID:	148610   Click image for larger version
ID:	148618   Click image for larger version
6.9turbo is offline
post #2 of 6 Old 07-31-2013, 07:42 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It's been done before but what size injectors are run in that 2000 model
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 6 Old 07-31-2013, 09:01 AM Thread Starter
6.9turbo's Avatar
I'll get the part #'s. Would there be any advantage over a stock turbo with intercooler setup?
Reason I'm asking is I will be doing an intercooler and want to know if this is better than stock.
6.9turbo is offline
post #4 of 6 Old 07-31-2013, 01:49 PM Thread Starter
6.9turbo's Avatar
has two different injectors #'s in it.
ID:	148722   Click image for larger version
6.9turbo is offline
post #5 of 6 Old 07-31-2013, 02:13 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
the ae is the long lead version of the ad. they are 140cc split shot injectors. it's not worth the effort
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 6 Old 07-31-2013, 02:22 PM Thread Starter
6.9turbo's Avatar
thought it was worth asking here. I'll just do a custom intercooler on my stock setup.
I have an intake off an early T444E so I won't need a different turbo, and an intercooler from an 01 psd
6.9turbo is offline
