New turbo? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-28-2013, 07:12 PM Thread Starter
New turbo?
Does anybody have any input on a new turbo? Was thinking about just a new stock turbo, or maybe a step up. Don't know a lot about turbos, want something reasonably priced, and that can just bolt in place of the stock one. Thanks.
Lutz'96 is offline
post #2 of 6 Old 07-28-2013, 08:46 PM
Quoted: 77 Post(s)
Feedback Score: 4 reviews
Why do you want a new turbo? Is something wrong with your stock one? What mods have you done?
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 6 Old 07-29-2013, 04:00 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Unless u have upgraded injectors, thereis no reason for a new turbo other then a stock rebuild
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #4 of 6 Old 07-29-2013, 08:52 AM Thread Starter
Guy before me built up the turbo and put the one off of his other truck on mine, stock turbo, but the turbo has around 60,000 more miles on it than the motor in my truck. That kind of makes me nervous, but it might just be me. Has a TS 6-position.
Lutz'96 is offline
post #5 of 6 Old 07-29-2013, 09:43 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
It's not hard to remove the downpipe from the EBPV. Get a 8mm 12-point wrench and remove the EBPV from the turbine housing by holding the wrench on one of the three bolts holding it on and tap the open end of the wrench with a small hammer or large rubber mallet till it breaks free. Remove EBPV from the system and pull the rubber inner boot off before the turbo on the other side. Reach in and spin the wheel, does it spin freely? Push in/pull out on the center of the shaft/wheel and try to rock the wheels (intake and exhaust wheels) to check for play. No play is great, very little play is ok, if you have play in any direction apply force in that direction and rotate the wheel to see if the play in the wheel is allowing the wheel to scrape on the housing that the wheel is in. Look at the wheels for chipping, pitting, bending, missing parts/fins.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #6 of 6 Old 07-29-2013, 08:16 PM Thread Starter
Thanks! No play in the wheel, so I guess I can spend my money on other parts.
Lutz'96 is offline
