Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 94-98 7.3L Forums > 94-98 7.3L Performance Parts
  #21 (permalink)
Old 07-03-2008, 11:43 PM
lukecline lukecline is offline
is your truck a 6.0 or 7.3?
  #22 (permalink)
Old 07-04-2008, 05:44 AM
Glasseater Glasseater is offline
that's a good question cause i'm 150ft above sea level and i've hit over 40 a couple times...
  #23 (permalink)
Old 07-04-2008, 06:43 AM
dhanna6powerstroke dhanna6powerstroke is offline
Got Smoke?
Originally Posted by GM Duraturd View Post
How much boost does your OBS make. With the mods in my sig I hit 21 psi just punching it on the street from 40 to 60 mph. I expected around 15 max out of the OBS.
I seen 25-26 at WOT when I owned that truck.
  #24 (permalink)
Old 07-04-2008, 06:55 AM
you won't see those types of numbers out of a stock (or intake and exhaust)OBS if you're empty... most i ever saw out of mine when it was stock (with intake and exhaust) was 18-19... i saw 21 loaded down
  #25 (permalink)
Old 07-04-2008, 06:57 AM
Got Smoke?
I put all the stuff on it that is in his sig. It wasn't stock.
  #26 (permalink)
Old 07-04-2008, 06:59 AM
whoops for some reason i thought it was another post you were talking about!! ok yeah i agree he should be much higher... boost leaks??
  #27 (permalink)
Old 07-04-2008, 11:36 AM
GM Duraturd GM Duraturd is offline
Send a message via AIM to GM Duraturd
when i was pulling a trailer with my 1979 f-150 on it i was seeing more like 24 psi when I got on it. But without a load it still tops at 21-22 all of the time. Should I have a concern or check anything?
  #28 (permalink)
Old 07-04-2008, 12:40 PM
Harohunter Harohunter is offline
PREEEEMIUM!!!!!!!!!!!!!!!
7.3 i also have a 1997 just not listed in Sig
  #29 (permalink)
Old 07-05-2008, 08:39 PM
Koonswala Koonswala is offline
my 94 7.3 stock with 3.5 down 4 out tops mt (empty for normal people) at 15 psi
  #30 (permalink)
Old 07-06-2008, 08:23 AM
John_DeereGreen John_DeereGreen is offline
Send a message via AIM to John_DeereGreen Send a message via Yahoo to John_DeereGreen
Stock downpipe, stock intake, with no cat or muffler and 18K turned all the way down I'll hit about 16 PSI. 18K turned up about 18-19 PSI.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
