Exhaust question!? - Ford Powerstroke Diesel Forum
post #1 of 29 Old 07-22-2013, 12:57 PM Thread Starter
Dirt rider1's Avatar
Exhaust question!?
I'm currently runnin jist a 3" downpipe.... Is this healthy fer my engine and turbo? Why/ why not?
Jordan
Jordan
(dirt rider1)
1997 7.3 Powerstroke 2wd auto
Mods:
-Muffler cut off
-Cat. converter gutted and gone
-Diamond Eye 3" downpipe
-MBRP 4" exhaust (runs in front of rear wheel)
-Dodge Towing mirrors
-AFE high flow intake
-Real Tree seat covers
-Real Tree floor mats
-blacked-out headlights
-cab lights
-6 by 8' flatbed
-KC lights
-silencer ring removed
-17ton anchor shackle
Dirt rider1 is offline
post #2 of 29 Old 07-23-2013, 08:12 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
You're fine with the 3" DP. If you still have a Cat chuck it and get a "3 1/2" test pipe". Stock DP is ****.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 29 Old 07-23-2013, 08:17 PM
977300's Avatar
I cringe every time I see a factory DP.
97 F-Super Duty 5 speed...T&S Performance Chip. More upgrades to come.
95 F-Super Duty 5 speed. The current project.
94 Dodge 2500 SOLD!
94 Dodge 3500 Sold to buy Superduty parts
95 Dodge 3500 Sold to buy more Superduty parts.
03 Dodge 3500 SRW, 4 door, 4X4, Cummins
Banks exhaust. Transmission upgraded.
977300 is offline
post #4 of 29 Old 07-23-2013, 08:59 PM
Quoted: 44 Post(s)
I think the OP is saying he has NOTHING aft of the downpipe, and wants to know if it's safe/wise. It's probably fine for the truck, but not too good for the occupants of the cab, since the exhaust is exiting right below the floor (and the cab isn't exactly sealed).
madpogue is offline
post #5 of 29 Old 07-23-2013, 11:03 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
It's obvious that yes it is, exhaust is better with back pressure better yes, but the turbo is more than you will ever need, here is actual proof of my last swap
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 29 Old 07-24-2013, 07:39 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Thanks Pogue, I didn't catch that. Not to mention that the soot will stick to everything down there. Also, if I'm not mistaken, when the soot gets wet I think it becomes more and more acidic.
Matt
'97
-Stage II trans.
BigFuel is offline
post #7 of 29 Old 07-25-2013, 04:49 PM
Hillbilly Deluxe
STROKED_NY_023's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Guys his sig says he has an exhaust, unless its a different truck or something...?
IF its just the DP, then i second everything mentioned above. PLUS your trans cooler lines are right there, if you had a leak in one of those lines or at the trans say bye bye truck. Trans fluid goes up quick...
As for the 3" dp, the outlet on the turbo is only 3", plus i don't think you will fit anything larger than that. So the 3" is fine up to the converter.
_____________________________________________
Seth
Stroked_NY_023
95' F-350 CCLB DRW POWERSTROKE
08 Axle/4x4 conversion, 5spd conversion, 6637, 5" SP exhaust, gearhead tunes
STROKED_NY_023 is offline
post #8 of 29 Old 07-25-2013, 09:38 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Well I don't know about his sig list as we keep giving him shat for the second to last item but he keeps it on there.
Matt
'97
-Stage II trans.
BigFuel is offline
post #9 of 29 Old 07-26-2013, 12:59 AM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
Branching off his post , i have a dp that sais ford on it but its not squashed like that one , any ideas?
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #10 of 29 Old 07-26-2013, 07:32 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Of a 99-03, they had 3" stock
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
