2WD to 4WD I need all the help i can get - Ford Powerstroke Diesel Forum
post #1 of 38 Old 07-21-2013, 04:37 PM Thread Starter
FeelDatPowerstroke's Avatar
I have a 1994 Powerstroke regular cab I have the 5 speed transmission and am looking to do a 2 wheel drive to four wheel drive conversion I know very little about it. The main things I need to know is exactly every part I need and off what year and model truck. Thanks for everyone helping I really appreciate it.
FeelDatPowerstroke is offline
post #2 of 38 Old 07-21-2013, 05:02 PM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
transfer case and linkage, driveshafts, front axle (look for a D60 as opposed to the TTB D50), everything associated with the front axle, front leaf springs, a 4x4 trans, the front end on the 2wds i do not believe is boxed so you will have to figure out something to do about mounting the front of the leafs. i'm sure i am forgetting something
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 38 Old 07-21-2013, 05:05 PM
01Crewcab7.3's Avatar
In my opinion it is nowhere near worth it. Just buy a 4wd. If you really want to do it though you will need to buy a donor truck. It will make things a lot easier.
Dana 60
4x4 zf5
Transfer case
Either modify your driveshafts or again get a donor
PCM
Column
Dash cluster
And some decent fabrication skills to get the front axle in there.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #4 of 38 Old 07-21-2013, 05:20 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Need to do an rsk from pmf or sky, that will make the front hangers for ya, need to remove radius arm mounts and add rear leaf mounts, axle, tranny/tcase, driveshafts, and drill holes in the cross member (at the oil pan) for your track bar mount, and t case shift linkage,
Keep in mind being as how your truck is a 94.5 you need that year or older axle so that the brake lines will work properly for the slide pin calipers
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 38 Old 07-21-2013, 05:51 PM
the baconator
Quoted: 153 Post(s)
Dana 60
4x4 zf5
Transfer case
PCM
Column
Dash cluster
no need for the pcm, cluster, or column? he's not swapping trans from auto to manual
early 95s had slide pins calipers as well. (i know as i have one)
post #6 of 38 Old 07-21-2013, 06:06 PM
If he wants the 4wd lights he will need the cluster. You are right on the rest I started going through a 5 speed swap in my head.
Tim
post #7 of 38 Old 07-21-2013, 06:18 PM Thread Starter
I will be wanting the electric shift 4X4 correct so I don't have to cut a hole in my floor or anything and I do want all the 4x4 lights and everything to work so will I need a new PCM? And what is a dana 60 and will it need to come off the same year truck or will I be able to get the parts of any obs 7.3 stroker
post #8 of 38 Old 07-21-2013, 06:26 PM
The Dana 60 is the front axle you will be using. It is a one ton solid axle. The Dana 50 TTB is a two piece axle that is prone to wearing out tire, a total PIA to lift, and has terrible ride quality.
Tim
post #9 of 38 Old 07-21-2013, 06:39 PM Thread Starter
so will it need to come out of the same year truck and will it be out of a 250 or 350 or either
post #10 of 38 Old 07-21-2013, 06:48 PM
350 only. 250 will be the Dana 50, you do not want that. 94.5-97 have the same brake set up, while the 94 and older have a different set up.
Tim
