180/100 vs d66 - Ford Powerstroke Diesel Forum
post #1 of 66 Old 07-20-2013, 01:33 AM Thread Starter
ole96stroker's Avatar
180/100 vs d66
Is anyone out there running stage 2 180/100 injectors.with a d66, just wandering if it's to much for this turbo thinking bout going 180/100 d66 efuel reg return clutch hpop and intercooler just didnt know if it would be a goodvsetup or not
******1996 ford f250 powerstroke 5 spd 4x4******
***170,000 miles, ts 6 pos, intake, exhuast***
ole96stroker is offline
post #2 of 66 Old 07-20-2013, 10:28 AM
01Crewcab7.3's Avatar
Beans recommends stage 2's or smaller but there are countless people running large hybrids on this turbo with out issue. You should be fine.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 66 Old 07-20-2013, 04:33 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
i have 160/100s, and a D66 with a WW2, and all the other mods. I feel that the turbo is very laggy and smokey until you get up in RPMs ~ 2100. on monday i am going to call beans and talk to them about a 1.0 housing to try and build boost lower and decrease some of the lag and the smoke.
once you get rolling though it is a whole lot of fun, i just don't spend much time above >2100 rpms
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 66 Old 07-20-2013, 08:37 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
I have basically same setup as Terryknight. I am running 160/80s though. And I have a 1.0 gated housing on mine rather than the 1.15 UN gated. Im sure that it will handle 200cc up to some 238/100s... What boost numbers are you guys seeing on your setups?
I think I'm running out of fuel pressure under full load and an trying to figure out why my boost numbers are low.
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #5 of 66 Old 07-20-2013, 10:13 PM
c69ss396's Avatar
I ordered a 1.0 housing today for the same reason, My truck is a beast over 21-2200rpms but is way to smokey in the lower rpms. I think the 1.0 housing will help. My egt's are a little high also. I'm blaming that on the turbo lag, it will cool down once I get some boost going. I think the 1.0 housing will help with that also...
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #6 of 66 Old 07-20-2013, 11:12 PM
the baconator
Quoted: 143 Post(s)
i have hit 32 but normally i am shifting long before then. normally when i am high in the boost i am concentrating more on driving than the gauges
post #7 of 66 Old 07-21-2013, 07:12 AM Thread Starter
What number's should I see with the d66 180/100's hpop?
post #8 of 66 Old 07-21-2013, 07:32 AM
the baconator
Quoted: 143 Post(s)
you HP wise? are you intercooled do you have e fuel? stage 2 injectors, normally 160/80s are capable of around 450 HP with the right supporting mods. 160/100s might net you a little more than that
post #9 of 66 Old 07-21-2013, 10:48 AM
Correct. With all of the supporting mods, proper tuning, 450 is no problem for stage 2's.
Tim
post #10 of 66 Old 07-21-2013, 11:45 AM
Doesn't Even Care
Quoted: 69 Post(s)
Yeah I just noticed something today...on my tw chip I am seeing 3k psi icp...on my php chip im only seeing 2500 icp on my scan gauge II. I need him to add more fuel and icp and I think ill be over 400 easy. The numbers in my sig are only on 25-27 psi
Nick
"The Mistress"
