need a ecu PLEASE HELP!!! - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-19-2013, 11:51 AM Thread Starter
C_gullion's Avatar
Ok so some may know I bought a 96 f250 as my first psd it is a 4x4 auto xlt I put all kinds of money into it and then I ran out of money had the truck lookin great then the ecu went out and I dont have the money to buy a new 400 dollar ecu so if anyone has an extra or somethin please let me know I can give some money!!!!
Corey
96 f250 eclb
Diy intake
Beans diesel 6 pos
4 inch rough country lift
3" diamond eye downpipe
6" mitre cut stack
Blackouts front back and top
Black and chrome hummer wheels
37" mickey Thompson baja claws
C_gullion is offline
post #2 of 12 Old 07-20-2013, 07:43 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Maybe try RockAuto.com as they are much less than $400, although I don't know with your location. I got one for my 94 from them for $115 plus refundable core. What is the PCM code on your PCM? Cheers!
Patrick Feeley is offline
post #3 of 12 Old 07-21-2013, 10:55 AM
Quoted: 50 Post(s)
Check the classifieds here and on the other diesel forum sites. How did you determine that the PCM "went out"?
madpogue is offline
post #4 of 12 Old 07-21-2013, 08:04 PM Thread Starter
C_gullion's Avatar
Started doing all kinds of screwed up stuff and the wts light would not come on sometimes and when it didnt it wouldnt start and sometimes I could disconnect the batt cables and put them back on and it would fix them but ill have to check the pcm code
Corey
96 f250 eclb
Diy intake
Beans diesel 6 pos
6" mitre cut stack
post #5 of 12 Old 07-21-2013, 09:49 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Possibly a shorted fuel bowl heater, check fuses
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #6 of 12 Old 07-22-2013, 05:10 AM
Quoted: 50 Post(s)
Have you tried disconnecting the fuel bowl heater? It may be messing with the power to the PCM. Also make sure the terminals in the fuse #22 socket are clean and that it has a good solid connection.
madpogue is offline
post #7 of 12 Old 07-24-2013, 05:35 PM Thread Starter
C_gullion's Avatar
Checked the fuses today everything was good on them
Corey
96 f250 eclb
Diy intake
Beans diesel 6 pos
6" mitre cut stack
post #8 of 12 Old 07-25-2013, 07:01 AM
superduty4x4's Avatar
You can buy PCM's for around $100... unless yours happens to have CA emissions. If it does, I happen to have a 96 CA emissions auto PCM.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #9 of 12 Old 08-01-2013, 02:33 PM Thread Starter
C_gullion's Avatar
My pcm code is F6TF-12A650-AYE
Corey
96 f250 eclb
Diy intake
Beans diesel 6 pos
6" mitre cut stack
post #10 of 12 Old 08-01-2013, 06:33 PM
Quoted: 13 Post(s)
That is a DPC-202 PCM with a NAW4 code (1996 Federal Automatic). Cheers!
