Next mod??? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-19-2013, 05:25 AM Thread Starter
chris79bronco's Avatar
Next mod???
Im kind of between dicisions on my next mod the my truck, Ive got about a grand to spend but want to make my purchase worth it, also dont know which one would come first, currenty my only mods are 6637, IDM, and dp with straight 5" to dual 6" stacks, its a 2wd long bed crew cab, 168K on the clock. Im wanting more power!! lol I was thinking prob a ts chip and ww2 or riff raff wheel. If you guys could think of something else I should prob go with first please give your advice. Thanks
97 CCLB, 6637 mod, IDM mod, Diamond eye 3" dp, 5" straight pipe, twin 6" stacks.
chris79bronco is offline
post #2 of 11 Old 07-19-2013, 06:37 AM
Sam Burton's Avatar
injectors!
Biggest bang for your buck on these OBS trucks, Rosewood has cheap stage ones and then get a custom tuned chip.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #3 of 11 Old 07-19-2013, 07:12 AM
Arcturus's Avatar
Injectors and a chip will put you about 50% over $1,000. I'd say a chip, custom tunes and gauges if you don't have any yet. That should put you just around a thousand dollars. I am in the same boat as you and will be doing this after I do some other preventative maintenance things like a total fuel bowl rebuild, new y pipe boots and a scan tool, jeez the list seems endless.
JackT
1996 ECLB 4x4 81k miles
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #4 of 11 Old 07-19-2013, 07:16 AM
Raul@Stealth Automotive's Avatar
custom tuned chip and gauges... and you will still have a lil left over to start saving for some injectors....
Raul@Stealth Automotive is offline
post #5 of 11 Old 07-19-2013, 12:37 PM
Sam Burton's Avatar
rosewood budget stage 1s are cheap, only $500, IF you have good cores, custom chip about the same.
1978 Ford Bronco
12v Cummins
Powerstroke E4OD
post #6 of 11 Old 07-19-2013, 03:02 PM
Arcturus's Avatar
Thanks, I didn't know you could get them that cheap. I was too focused on looking at the baby swamps.
JackT
DIY 6637, Hpx, E4OD
First boat Arcturus
2008 Kubota L-39
Arcturus is offline
post #7 of 11 Old 07-19-2013, 04:45 PM Thread Starter
Dont have any guages yet so prob a good idea to get them. Also with the injectors, if I get stage ones or two's and dont have a chip the computer will think they are stock and treat them as such, will that harm anything? Im thinking a custom tuned ts and a set of guages prob best then save for injectors, and maybe the wicked wheel 2
post #8 of 11 Old 07-21-2013, 08:13 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Custom tunes, gauges, ww2 all day under 1k and best bang for your buck bud
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 11 Old 07-21-2013, 09:55 AM
01Crewcab7.3's Avatar
GAUGES. Do not star adding fuel until you get gauges. Like Raul said, gauges and a chip. Then get injectors.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #10 of 11 Old 07-21-2013, 11:11 AM
Gaius's Avatar
Quoted: 50 Post(s)
I see you recommend the WW2 several times to people. Have you run one yet? Worth the money and time to install?
OP, I would get custom tunes and some sort of gauges (I wish I had gotten the Edge CTS instead of my full set of EV2s). Then save for some injectors if that's not enough for you.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
