Exhaust Hanger Disconnect - Sort of Urgent - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-11-2013, 10:47 AM Thread Starter
IU 89's Avatar
How do you disconnect hanger arm from hanger when replacing the exhaust? 6197506623. Under the truck and not having much luck. Thank you, Chris
IU 89 is offline
post #2 of 5 Old 07-11-2013, 10:57 AM Thread Starter
IU 89's Avatar
Assume lots of lube :-). Actually got one out. Miracle.
IU 89 is offline
post #3 of 5 Old 07-11-2013, 11:44 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Honestly unless you have the tool to hold the rubber part easiest way is to hack off the hanger rod, but you can hold the rubber hanger by hand and lift slightly and push the rod out on most of them, but the sawzall is much easier
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 5 Old 07-11-2013, 05:24 PM Thread Starter
IU 89's Avatar
Sawzall would have been a great idea but I muscle "blanked" them out which now means I am tired. 6 hours from the time I checked into the Auto Hobby Shop at MCRD until I checked out - great facility btw, and I am done. I won't bore anyone with the details but I may cut the exhaust so it is just short of the rear wheel as clearance is 1/2" - 1". Seems too small a margin. Thank you all for your texts and emails with ideas and advice about the Hangers. Now ready to enjoy a Cerveza! Cheers, Chinny......may post a few pics later.....
IU 89 is offline
post #5 of 5 Old 07-16-2013, 11:52 AM Thread Starter
IU 89's Avatar
So I installed the exhaust kit last Thursday and I really tried to get it in there without having to remove/relocate the spare. It is in however I have minimal (less than an inch) of clearance between back wheel and exhaust. Any issue with me cutting it short of the wheel?
IU 89 is offline
