diamond eye part number difference? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-10-2013, 03:40 AM Thread Starter
96' crew cab long bed f350. I am trying to order my new exhaust (diamond eye)today and found a couple of numbers that I can't tell what the difference is. The two numbers are k4306a-rp and k4307a-rp. There is no difference in the descriptions. I just don't want to order the wrong one. Thanks, for any insight.
cruisertom is offline
post #2 of 6 Old 07-10-2013, 07:13 AM
Gaius's Avatar
Quoted: 50 Post(s)
Looks like the 4306 uses the stock cat. Might want to give Diamond Eye a call first.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #3 of 6 Old 07-10-2013, 10:03 PM
IU 89's Avatar
Hi, I have ordered and am installing tomorrow the K4307S which is the Turbo Back / Cat Delate (Off-Road Single) and the K4306 has the Cat. That was my understanding from Diamond Eye when I placed my order. Good luck, I know I am going to need it, never tried this before but should be fun. Any tips for a smooth removal and install are appreciated.
IU 89 is offline
post #4 of 6 Old 07-11-2013, 05:38 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
To bad I moved, I got down pipe installs to half hour times now, it's pretty easy tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 6 Old 07-11-2013, 10:42 AM
IU 89's Avatar
Hanger Emergency
How do you disconnect hanger arm from hanger when replacing the exhaust? 6197506623
IU 89 is offline
post #6 of 6 Old 07-11-2013, 03:31 PM
superduty4x4's Avatar
Pull, tug, swear, and repeat until it pops out. A little WD-40 or something on the rubber doesn't hurt to help it slide off the hanger.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
