Water Methanol Injection without intercooler - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-08-2013, 04:42 PM Thread Starter
Boise Outlaw's Avatar
Noticed that whenever I hit the steeper hills over 2k rpms with 5lbs of boost or more my egts shoot up over 1200, I have to back her off to get them down again and can only cruise at 35-40mph in a 55 zone. I plan on installing an intercooler eventually but am still running down the parts. Anyone running a Water/Methanol setup in their rig thats non-intercooled? Where did you install the sprayer nozzle and what size are you using? What were your egts like pre and post install?
Have been reading up alot on this site:
Do It Yourself Water Alcohol Methanol Injection | Parts List
97 OBS F250 Ext Cab Long Bed 4x4 ZF Swapped
VO conversion, TS 6 Position Chip, E Fuel, 6637 Filter, EBPV delete + PCV Reroute, Diamond Eyes 3" Downpipe
Boise Outlaw is offline
post #2 of 13 Old 07-08-2013, 04:47 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What I do even with an intercooler is drop a gear, rpms get pretty high, but boost is up, egt down, and speed isn't so slow, as far as water meth I've seen that DIY version too and would love to install one as well
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 13 Old 07-08-2013, 06:22 PM Thread Starter
do you just downshift on the column? I'm running an auto tranny unfortunately but that'll change in the future as well
post #4 of 13 Old 07-08-2013, 10:09 PM
Gaius's Avatar
Quoted: 40 Post(s)
What injectors and tunes do you have?
You can shift the auto you know. OD button wil get you into 3rd...
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #5 of 13 Old 07-09-2013, 07:43 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I hauled 17k and at some grades went down to 1st gear just to keep it moving, so yes you can manually down shift an auto
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 13 Old 07-09-2013, 08:29 AM
gabegoforth's Avatar
With an intercooler most of us can run our foot on the floor and keep out of trouble. I normally hit the OD off button and spool up to about 2700rpm with 15+ lbs of boost and watch the egts drop.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #7 of 13 Old 07-09-2013, 05:07 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
The higher your rpms, the more air u are pushing and the lower your egts will be
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #8 of 13 Old 07-09-2013, 05:12 PM
Sam Burton's Avatar
i ran a Cooling Mist stage 1 kit on my old OBS with out an intercooler and it worked great.
I found once it came on my EGTs stayed steady and stopped climbing. that was with stage ones and a 5 spd 35s and 4.10s usually pulling about 10000lbs up 5-8 % grades. I ran duel nozzels and used a lot of water though.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #9 of 13 Old 07-09-2013, 05:43 PM
I ran water/meth on my old 6.5 and it didn't have an intercooler, it helped tremendously. I just tapped into the intake manifold.
2006 White F350 CCLB 2WD
dowmace is offline
post #10 of 13 Old 07-10-2013, 10:38 AM Thread Starter
Right on, I had forgot about the OD button but will give that a try. I'll go ahead and give the water/meth setup a go if she is still running hot. Cant complain for a $200 performance mod.
