CX Racing Inter cooler Install with lots of pictures. - Ford Powerstroke Diesel Forum
post #1 of 20 Old 07-03-2013, 07:07 PM Thread Starter
gabegoforth's Avatar
So I got my Inter cooler today and started right a way. So it might take me a few more days to finish do to some unexpected and expected slow downs. My truck was in a fender bender with the previous owner and they stuck the gas bumper on it. My ford buddy has been sick so I haven't been able to get up to his place to get one. Plus my head light bracket thing broke. Ill also half to do some welding on the Radiator support as it has started to crack. My Brother helped me on this one, so hes the one cutting the holes. I'll be adding photos as it gets closer to being done.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #2 of 20 Old 07-03-2013, 07:17 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Looks good so far, but why cut the condensor supports off? I just flattened both mine, make sure to give us a review too
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 20 Old 07-03-2013, 07:19 PM Thread Starter
IDK seemed like a good idea at the time. What do you mean flattened? I took them out for more air flow as little as it may be.
post #4 of 20 Old 07-03-2013, 07:35 PM
drivininidaho's Avatar
Quoted: 86 Post(s)
looking good man! good luck with the install!
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is online now
post #5 of 20 Old 07-03-2013, 07:36 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
There is a bend in them, just put them in a vice and straighten out, flat, and put new holes where they hold the condensor farther back, those plates should do fine regardless tho
How did you mount the IC to the frame?
EDIT: nvm, I see the bar top mounts
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 20 Old 07-03-2013, 08:35 PM Thread Starter
I'm working on the bottom mounts. I lost on at napa when I ran for bolts I think. So I'll have to go back Friday and see if they have it. Then work on my tranny coolers and bumper will take some time. The kit did come with spacers for the bumper.
post #7 of 20 Old 07-04-2013, 02:30 PM Thread Starter
It's done, using a modified bracket till I get the one back from napa. Also I'm working on my tranny coolers. Right now I'm running the bigger of the 2 that I have. Maybe get a used A/C condenser. Do you guys think that would work as a enlarge tranny cooler?
post #8 of 20 Old 07-05-2013, 06:30 AM Thread Starter
CX Racing Inter cooler Install with lots of pictures.-imageuploadedbyag-free1373034619.210645.jpg
post #9 of 20 Old 07-05-2013, 07:59 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Looks good buttoned up, and as far as an ac condencer for a tranny cooler it's pretty large for the pump in the trans to push through, don't see why it wouldn't work other than that though
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 20 Old 07-05-2013, 08:41 AM Thread Starter
Hm yeah I'll have to keep thinking about it. The nice thing about them is that there thin. And after all of what I've had to stuff in there it would be nice. Right now my tranny cooler is strapped to my grill.
