17* hpop - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-29-2013, 02:38 PM Thread Starter
17* hpop
If I was to get sage 2 injectors on my 94 would a 17* hpop be the way to go? There are a bunch of different options for a 17*, and I was wondering if a stock 17* hpop would work.
94.5 F350 CC LB 4X4 5 spd
AFE Stage 2
4" Exhaust
Turbo Upgrade
TS 6 Pos Chip
FPR Shim
Equailzer hose
3 gauge a pillar pod, Pyro, Boost, and soon to come Fuel Pressure
kevinwoo11 is offline
post #2 of 8 Old 06-29-2013, 02:47 PM
01Crewcab7.3's Avatar
Yes a 17* would be a must. T500, adrenaline, srp1.1 are all great options.
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 8 Old 06-29-2013, 02:54 PM Thread Starter
Thanks I have a shop here locally that deals with the terminator pumps are they a pretty good pump. Heard anything bad on them?
AFE Stage 2
4" Exhaust
Turbo Upgrade
TS 6 Pos Chip
FPR Shim
Equailzer hose
post #4 of 8 Old 06-29-2013, 05:00 PM
Not one thing. I know he has a core shortage right now so he is requesting people send in their cores first and building it.
Tim
post #5 of 8 Old 06-30-2013, 05:00 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
if you have a 94.5 to a 95.5 with the early front cover, you will either need to change or mod the front cover or get a pump with the anti drainback feature. i have a T500 been running it for 16 months it has been great. running 160/100 injectors
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 8 Old 06-30-2013, 08:26 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
A stock 17* won't work on the rig in your sig, but I have heard nothing bad bout the terminator pumps
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 8 Old 07-01-2013, 07:49 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 43 Post(s)
^^Agreed. You can only use the early 15* HPOP in your truck. T-Engineering can mod your HPOP into a T500 but you will have to send it to them first.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #8 of 8 Old 07-01-2013, 12:05 PM
the baconator
Quoted: 143 Post(s)
i think stealth makes a version of their SRP pump as well
