Injectors and Turbo help - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-17-2013, 06:49 PM Thread Starter
MDdiesel's Avatar
On my truck I have a ts 6 pos. chip, tymar intake,and aftermarket turbo back exhaust. I want to get new injectors and a turbo. What is the best stage, kind, and place to get injectors. Also would it be better to buy a bigger turbo all together, if so what kind or just rebuild on. Any info will help.
Thanks Nick
'97 f-350 rclb auto 4x4
Mods- Baby Swamp injectors, Tymar intake, Dieselsite coolant filter, TS 6pos chip,
3 pillar gauges - pyro,boost,trans temp, 3in dp, 4in exhaust, 8in Catstack, 4.10 gears.
MDdiesel is offline
post #2 of 14 Old 06-17-2013, 06:52 PM
c69ss396's Avatar
I prefer Swamps for injectors and beans has bolt in upgrade turbo
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #3 of 14 Old 06-17-2013, 07:46 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Rosewood diesel shop, but as far as turbo how big of injectors are you going?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 14 Old 06-17-2013, 08:12 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
The OP is my cousin... What he wants to something more then stock, but doesnt wanna take away the daily drive-ability. Im guessing stage 1? I have an 6.0 so I dont know the injectors that these have plus how they step up "stage" wise.
MrOneEyedBoh is offline
post #5 of 14 Old 06-17-2013, 09:50 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
If he wants to keep it simple than stage 2's and a ww2 with custom tunes written for them, also a sd 17* pump if the stock one is getting weak now
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 14 Old 06-20-2013, 07:48 PM
spartan-alteran's Avatar
I got a garrett turbo in mine runes good and at times I get over 25mpg on the highway at around 90-100KMH + I can hull and un stuck truck out of the ditch no prob
spartan-alteran is offline
post #7 of 14 Old 06-22-2013, 02:21 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
what are your goals for your truck? and what's your budget? have you done anything about supporting mods? e fuel, IC, Trans? where in MD are you?
most people say stage 1s with an IC and stock turbo is a great all around combo. this may have change with the advent of the WW2
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #8 of 14 Old 06-23-2013, 06:48 AM
OL' OutLaw's Avatar
if you go bigger than stock injectors, remember that the FIRST thing you're gonna need is a Transmission....the stock trans is weak at best, and with more power on tap, it will go away almost instantly......
think trans first, (with trans temp gauge), then aftercooler, (with Pyrometer), injectors, (with Manifold pressure gauge), and D66 turbo.....and E-Fuel is a VERY good mod, probably the best one I've done....you really should do the E-Fuel when you have the turbo off and you're doing the aftercooler.....smoother, more power, (slightly), starts easier, and now, I can actually WORK on the top of the engine.....great mod....
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Exhaust Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, W/ SD Trans Lines, Tru-Cool Max, PML Trans Pan, Bumper Mod, IssPro Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".
OL' OutLaw is offline
post #9 of 14 Old 07-02-2013, 08:21 AM Thread Starter
MDdiesel's Avatar
my goal for my truck is to get it around 500hp. i don't really have a budget not trying to spend a crazy amount though. the mods i have done now is a tymar intake, 6 pos chip, dp and stack, and a jasper rebuild trans (don't know if it has a upgraded clutches- was like that when i got my truck). im in central MD.
MDdiesel is offline
post #10 of 14 Old 07-02-2013, 08:35 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Odds are 500hp will kill a jasper. Plan on it.
You will spend a crazy amount to have 500HP, if you build it to be reliable. Plan on $6k not counting the trans.
CT Performance, Inc. is offline
