Water/Meth Big Questions I'd love some help - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-11-2013, 12:39 AM Thread Starter
Asian Cowboy's Avatar
Arrow Water/Meth Big Questions I'd love some help
So, I have decided on CoolingMist stage 1 deluxe kit coming in at $305 as the best bang for the buck and from many recommendations that their pumps actually do what they're supposed to do.
My questions:
1. For strictly EGT control purposes is a water/meth completely safe for my engine given that I do not goof on the installation and install a shunt valve so water doesn't leak into my cylinders? I would most likely be runnin' distilled or filtered water to keep particles out of the engine.
2. I have heard about runnin' the water/meth pre-turbo over the post-turbo may be more beneficial from a few friends and from a video I shall reference. Is there any major/minor difference in runnin' pre-turbo or post turbo?
3. If I do decide to run water/meth from windshield washer fluid, is there anything I should watch out for? I am a bit nervous about the whole puttin' water into my engine but from watching videos and readin' stuff makes sense since I'm injecting a fine mist. I sure do want the reassurance from people who have had or has experience runnin' water/meth.
4. I may be takin' a bunch of precautions and sound a bit paranoid, is it necessary to install the shunt valve and use filtered water? And since we're injector WATER into the cylinders, am I gonna see some rust if I take the apart the engine in the future? From my logic, I don't think I'd see rust since the water has already evaporated and didn't have to chance to sit on the cylinders and eat away.
And hello, I'm quite new to the org.
1997 Ford F-350 7.3 PSD
*140 HP Stage III Dynomite Diesel Injectors
*DP Tuner mod stock, drive-thru, econo 80, see ya 140
*3in downpipe, 4inch "straightpipe" no kitty, gutted muff
*1.0 A/R Turbo Housing
*DIY CAI
Asian Cowboy is offline
post #2 of 9 Old 06-11-2013, 12:50 AM
01Crewcab7.3's Avatar
I do not know the answer to all of your questions but I know at least this much. Your concern about rust is not a problem. As you stated the water evaporates and does not leave any moisture behind. Also I have heard from people that run the kits that they shut off the kit a few miles before where they are going as to make sure any and all water has evaporated. Hope this helps some.
Also, welcome to the org!
Sent from AutoGuide.com App
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #3 of 9 Old 06-11-2013, 12:57 AM Thread Starter
Thanks for the speedy reply about rust. Now the rest of the questions gotta be answered! Haha
*DIY CAI
post #4 of 9 Old 06-11-2013, 07:45 AM
Sam Burton's Avatar
I ran the same kit on my old OBS and it worked great.
I ran mine post turbo so I don't know anything about running pre turbo, never even thought about it.
as has been stated rust isn't an issue, the stage one kit uses a boost reference switch so you don't have to worry about any water in the system when you stop unless you are beating on it the same time you shut it off!
distilled water is a good idea, but I used to run plain old tap water if I didn't have access to the good stuff.
windshield washer fluid does give it a nice kick in the pants, just make sure you get the plain stuff and not the stuff with a bunch of additives.
1978 Ford Bronco
12v Cummins
ZF-5 NP 205 10.25 rear Dana 60 front
Denny T fuel pin 366 governor spring
HX 35 turbo BD exhaust brake
Powerstroke intercooler
1990 F-350 Crew-Cab Short Box XLT 4x4
Powerstroke E4OD
170cc stage 1 injectors, superduty intercooler, flowmaster 3" down pipe, 4" exhaust, 6637 filter, 17* HPOP, Wildman tunes, build E4OD, 5 disc billet converter, Irate E-fuel, 1.0 exhaust housing, WW2, CCV mod, homemade RSK
Sam Burton is offline
post #5 of 9 Old 06-11-2013, 01:13 PM Thread Starter
Makes sense. Thank you!
*DIY CAI
post #6 of 9 Old 06-12-2013, 07:55 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
You don't have a fish/aquarium store in town Sam?
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #7 of 9 Old 06-12-2013, 08:55 AM
Sam Burton's Avatar
I assume you are talking about the water, there are lots of places to get it from but I tow over some pretty long pulls and would use ALOT of water, I ran a 8 gallon tank and sometimes would drain it pretty quick so I would use whatever I could get.
I like to pass uphill pulling a trailer.
1978 Ford Bronco
12v Cummins
Powerstroke E4OD
post #8 of 9 Old 06-12-2013, 09:00 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
I carry this for the horses. Hook it to a hose and flow.
Aquarium Pharmaceuticals Tap Water Filter
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #9 of 9 Old 06-14-2013, 12:48 PM
rsfvscott1's Avatar
90% of what I've read says post turbo is best pre turbo you're taking a chance of a large drop(s) messing with the turbo.
1996 F250 Exstended Cab 4x4
Tymar intake
Tymar 3" down pipe
TS 6 position chip
Glowshift gauges
3:55 gears
2nd generation wicked wheel
1995 chev airconditioner condenser for trans cooling
377,000+ miles on clock and still climbing
rsfvscott1 is offline
