Best Gauges? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 46 Old 06-10-2013, 07:23 PM Thread Starter
LilBit 4x4's Avatar
Best Gauges?
Any suggestions on gauges? Currently only have stock.
LilBit 4x4 is offline
post #2 of 46 Old 06-10-2013, 07:46 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I run auto meter z series, love them, I also run an aero force interceptor scan gauge, and saving pennies for the dp tuner infinity
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 46 Old 06-10-2013, 08:33 PM
01Crewcab7.3's Avatar
I have Isspro ev2's on all of trucks. They are pricey but by far the best on the market.
Sent from AutoGuide.com App
stealthrunner likes this.
Tim
2001 F-250 Lariat CCSB, 4x4, ZF6 249k, 6.5" Procomp lift, 37" Toyo M/T's, 20" Fuel Hostages. PIS 160/30's, PHP Hydra, 6637, 4" exhaust, Tank mods, ISSPRO's, 08+ mirrors/tailgate/tail lights, M12000 winch.
01Crewcab7.3 is offline
post #4 of 46 Old 06-11-2013, 10:16 AM Thread Starter
LilBit 4x4's Avatar
Thank you! Looking into it now.
1995 F350 7.3L DI Turbo Crew Cab Long Bed
Project Truck in the Making
<3
Nicole
post #5 of 46 Old 06-11-2013, 10:33 AM
I think thoroughbreddiesel has the best price on a kit.
Tim
post #6 of 46 Old 06-11-2013, 12:26 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Another fan of ISSPRO (I ran the EV's on my 94). Cheers!
Patrick Feeley is offline
post #7 of 46 Old 06-11-2013, 12:47 PM
jimhuntertx's Avatar
Quoted: 3 Post(s)
Send a message via Skype™ to jimhuntertx
I run Auto Meter Classic gauges. Very accurate. All depends on what you are looking in the way of looks. Auto Meter has a pretty deep line up.
JIM
97 F-250 2wd Extended Cab Longbox, Pyro,boost and trans temp guage, 3" down pipe,
New E4OD Trans, TS 6 chip
Banks TransComander, 4" to dual 4" Bullydog 4" Dual Exahust , DIY Tymar intake w/ K&N Filter, Shimmed FPR
jimhuntertx is offline
post #8 of 46 Old 06-11-2013, 01:48 PM
I've always ran Autometer Sport Comp's, not the most expensive but they're accurate and look good. I will say… I just baught some for my truck, first set I've had to buy for over 10 years. The new ones are made a lot cheaper than they used to be. My old guages I have laying around are all metal construction and the new ones are plastic with a metal trim ring. I guess that's what everything has come to in this country, make it look the same but make it cheaper to produce. We'll see how they hold up, but my guess is they'll be just fine. I just need to get over the whole plastic thing.
WishinIwerFishin is offline
post #9 of 46 Old 06-13-2013, 12:15 PM
Tinman23's Avatar
I've had a good experience with ISSPRO EV2's. Currently don't have anything in the Powerstroke, but ISSPRO will probably get the nod when I do. Or I may spring for something like the Edge CTS for its capabilities...but haven't looked in depth at it yet.
-Jody
96 F-250 XLT CCSB | 4x4, 7.3L PSD, E4OD, 188k miles | DIY 6637 intake | Diamond Eye 4" exhaust w/ 3" DP | new GPR | cleaned FPR screen | FPR shim | DieselSite 203* t-stat| wore out tires & empty pockets
Tinman23 is offline
post #10 of 46 Old 06-13-2013, 01:04 PM
c69ss396's Avatar
I run the autometer sport-comp digital gauges,
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
