Any chips work to read trouble codes on '96?? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-10-2013, 02:40 PM Thread Starter
Woodturner Nate's Avatar
Quoted: 2 Post(s)
I have another thread going about which DTC scanner to buy, but it occurred to me that I might be able to kill 2 birds with 1 stone. I've been thinking about a chip anyway. Does anyone have a chip that does both that will work on a '96. They are apparently NOT OBDII compliant, even though they are supposed to be. The ScanGauge II doesn't work.
2007 F350 King Ranch CCLB 4x4
WVO conversion in planning
RIP 1996 F250 eclb, 4x4, 7.3L PS
Viair 444C/6g air tank on frame, Hadley air horn, Hella auxiliary reverse light, DIY WVO conversion; Efuel, dual FuelLab FPR's, 90g RDS tank, aluminum tube-in-heater hose, hotfox heated fuel pickup, copper coil-wrapped filter, 40-plate FPHE, auxiliary coolant pump, 2000lb winch-crane bolted to the frame. Ranch hand front bumper. Big winch.
Woodturner Nate is offline
post #2 of 13 Old 06-10-2013, 02:47 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Dp tuner infinity, reads codes, works as a gauge set up, and can do custom performance tuning, also can use it to choose selections on a current 6 pos chip
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 13 Old 06-10-2013, 02:51 PM Thread Starter
Quoted: 2 Post(s)
So, you have one? I've heard negative things about DP tuner, so I'm all ears if you have experience.
post #4 of 13 Old 06-10-2013, 03:17 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
I have tony wildman tunes, but will be ordering the infinity as soon as funds allow, I don't have dp tunes, and have never heard anything bad about their tuning aside from guys with pmr rods who add bigger sticks and turbo's that blow rods but that I beleive is their own fault, guy is just bringing as much power to the table as possible, if you don't support the mods they will destroy a block
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 13 Old 06-10-2013, 03:40 PM
c69ss396's Avatar
I like the infinity also, its a monitor, diagnostic aid and tuner all in one..
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #6 of 13 Old 06-10-2013, 03:42 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
But you asked what did it all and that is going to be the best bet for everything, now you could get a custom 6 pos chip and edge cts, that would tune, check codes, and monitor everything
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 13 Old 06-10-2013, 07:36 PM Thread Starter
Quoted: 2 Post(s)
A custom chip and edge CTS would cost me a grand. Too much $$ for this guy.
I feel like I'd be missing out by using just a three stage programmer instead of a custom tuned chip. Maybe not. I can't afford the 6 position chip AND the Edge CTS together. If the CTS could have custom tunes in it, it would be golden.
post #8 of 13 Old 06-10-2013, 07:39 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Yeah but then it would cost more
Find a used chip for like $150-200, then send it off for custom tunes for $150, and buy a used cts for $150-250, still way under 1k, keep in mind you still need the egt gauge
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #9 of 13 Old 06-10-2013, 07:58 PM Thread Starter
Quoted: 2 Post(s)
already got an EGT gauge. Any compatibility issues?? It's a "Ford Racing" pyrometer gauge.
I haven't seen the Evolution CTS used on ebay; only the older evolution models for around the same $$$ range. They don't do the display, but read codes, I think. Gotta have the display if I'm gonna do this.
post #10 of 13 Old 06-10-2013, 08:03 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Check the classifieds here, people sell them bout every week, cheap too
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
