is everything the same... i meen mount wise.. i know i need the flywheel and master cylinder and all that good stuff but are the cross members and tranny mounts the same???
![]() if so is it real hard to do and an average time it takes to do..... |
it not that hard you will need some of the following
5 speed transmission flywheel clutch slave cylinder hydrualic resivor and line to the slave cylinder a different driveshaft not sure on the crossmember and a hole int the floor for the stick shift to go throught. I also can't tell you about your transfer cas weather is will bolt up or not. so I would do some research |
...and pedals, and a steering column ( I guess you could leave the auto column).
The best way would be to find a parts truck, same year and wheelbase, and swap all the parts you need. It'll be worth it, cause auto's SUCK! |
i have a whole other truck(94 ext cab 5speed 4x4 psd)so im pretty sure i have all the parts i need. what about computers>?????????????
