External Wastegate Size and Placement - Ford Powerstroke Diesel Forum
post #1 of 22 Old 06-07-2013, 07:51 PM Thread Starter
Pwnm30rdi3's Avatar
I'm about to drop the motor into my truck.
I'm looking to build 50-60 PSI with my modded H2E and 300/200's.
In the future I will be adding a 150-300hp shot of nitrous.
What size wastgates should I purchase?
I was thinking of running 2 wastgates, one in each up-pipe right before the turbo.
Thanks guys for all of your help!
Andrew
1997 F350
Mahle Ceramic Coated Pistons (De-lipped), Billet Crower Connecting Rods, DI Chromoly Push Rods, Beehive Valve Springs, Fire Ring Headgaskets, ARP Head Studs, Mike's Main Girdle, Melling LPOP, Terminator Dual HPOP, 300/200 Injectors, Dual SD Fuel Pumps, Billet Aluminum Intake Plenums, 6.0 Mishimoto Intercooler, Compound Turbos (Primary = 62/68 & Atmospheric 82/88), John Wood Tranny, 4921 Transmission Cooler, Batteries Relocated to Bed
Pwnm30rdi3 is offline
post #2 of 22 Old 06-09-2013, 04:28 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
i know you are way above my pay grade. and probably most others on here. if you go to the army there are more people into the performance side of things
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 22 Old 06-10-2013, 09:00 AM Thread Starter
Pwnm30rdi3's Avatar
I wouldn't say that at all! I would just say that I spend my money recklessly...
Thanks for the response. I will check out the army and see if anyone there can offer some help! Thanks!
1997 F350
post #4 of 22 Old 06-17-2013, 08:54 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
wastegates arent easy to fit in an obs. it will require some firewall modifications and most guys mount them in a ballance tube right behind the turbo and requires lots of cowl modifications.
most obs guys use a aftermarket high pressure back pressure sensor and monitor back pressures heavily thru custom tunning.
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #5 of 22 Old 08-27-2013, 09:10 AM Thread Starter
Pwnm30rdi3's Avatar
Just a little update. I went with a turbosmart 45mm wastegate. I had a local header shop weld the wastegate flange onto the top of the cast steel t4i manifold.
To get the wastegate to fit behind the turbo I had to replace the body mount bushings and remove a section of the factory heat shield material to prevent rubbing.
1997 F350
post #6 of 22 Old 08-27-2013, 01:15 PM
ol_Blue97's Avatar
got any pics with it out of the truck?
FRANK THE TANK
post #7 of 22 Old 08-27-2013, 05:31 PM Thread Starter
Pwnm30rdi3's Avatar
Yeah, I actually do happen to have a picture.
1997 F350
post #8 of 22 Old 08-28-2013, 07:33 AM
Red '97's Avatar
thats a really builtazz motor.... your sig is like eye candy lol
-Conner
1997 F-250 Long Bed Extended Cab
--7.3 Powerstroke E40D Auto
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
-3 inch DP, 5 inch under truck, 6 inch Mitre!!
-2nd gen Wicked Wheel from Dieselsite
-Tony Wildman 6 Position Chip
Broke College Kid Mod
Now residing in LARAMIE, WY for school at the University of Wyoming! Hit me up if youre around, I'm always down for a hot rodding adventure
"Never cut what you can untie"
--Buckaroo Proverb
Red '97 is offline
post #9 of 22 Old 08-28-2013, 11:16 AM Thread Starter
Pwnm30rdi3's Avatar
Thanks
I miss driving my truck.. So far this has been an 8 month long build. Doing this stuff is really time consuming and burns a huge hole in your wallet. I just keep telling myself that this will be worth it when it's all done!
1997 F350
post #10 of 22 Old 08-29-2013, 07:32 AM
Red '97's Avatar
yeah ill say that thing will haul the mail. how much hp/torque will that setup lay down, i cant help but notice all the bottom end mods
-Conner
--4.10 Rear End
--280,000 Miles
-Napa 6637 DIY CAI
--Buckaroo Proverb
Red '97 is offline
