Boost gauge? problems. - Ford Powerstroke Diesel Forum
post #1 of 17 Old 03-15-2008, 06:45 AM Thread Starter
OldSchool7.3's Avatar
Question Boost gauge? problems.
Hey guys, i just got my gauges installed and the boost doesn't move at all. i was wondering if this is normal or would i really have to get on it to see it move. The guy that installed them said they don't really get much boost but i thought it would at least move from 0. Thanks
1997 F-350 PSD XLT Crew Cab Auto 4x4.
White & Gray.
87,000 miles.
MBRP exhaust w/ 5" Chrome Tip.
AFE Stage 2.
Tony Wildman 6 Position Chip.
Auto Meter Z Series Gauges (Boost, Pryro, Trans).
Wish List: Husky Floor Mats, Leveling Kit, Window Tint.
OldSchool7.3 is offline
post #2 of 17 Old 03-15-2008, 07:07 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Sounds to me like he didn't install the boost line in the correct spot, or it is possible that the gauge is bad. Those trucks boost around 16-18 psi stock. Check out this website and see if it helps. You should be able to tell by the diagram if it hooked up right.
Diesel Injection Service (DIS Main Page)
dhanna6powerstroke is offline
post #3 of 17 Old 03-15-2008, 07:10 AM
Desert Shield/Storm Vet
vitalidle's Avatar
Also you can't be in nuetral and check the boost gauge. You need to run the truck down the road to put a load on the engine to get boost
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #4 of 17 Old 03-15-2008, 02:23 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
Where is the pickup installed?
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #5 of 17 Old 03-15-2008, 04:49 PM
AntiqueIronHauler's Avatar
Send a message via AIM to AntiqueIronHauler
i just put one in today, T'd it into the map line. Normal cruising it reads 0, slight accel around 1500-2000rpm will read 5-10, put her to the floor and the needle becomes shakey and will see 22. Does this sound about right?
AntiqueIronHauler is offline
post #6 of 17 Old 03-15-2008, 05:07 PM
strokermann's Avatar
normal crusing aroun 55-60 i see at least 5-8psi. and idle i seet at least 1 psi.
CB Radio- General Lee
7.3l 99 f-250 SD
4 INCH TURBO BACK TO 6 INCH MITER CUT STACKS CURIOSTY OF GRAND ROCK AND COWBOY DIESEL PERFORMANCE.
TS 6 POSTION CHIP. stock,high idle,50,75,100,140hp.
strokermann is offline
post #7 of 17 Old 03-15-2008, 05:22 PM
cchase's Avatar
i see zero at idle, then it moves when i accel and drops to like zero crusing on the highway.. weird cause i know i got boost
On vacation from a truck for a year or...
Looking at 6.4s Moving in a few months then hopefully buying my dream truck!!!
Driving an Audi till then...
but at work I drive
16 E-450s 7.3 powerstroke Ambulances
7 Duramaxes
1 GMC Kodiak Ambulance
NO CUMMINS.....
cchase is offline
post #8 of 17 Old 03-15-2008, 08:41 PM Thread Starter
i see zero all the time. i will take it back to the guy monday morning. the install looks exactly like he diagram. Thanks for all your help guys, i hope it's not a bad gauge.
White & Gray.
87,000 miles.
AFE Stage 2.
post #9 of 17 Old 03-16-2008, 12:41 PM
Is there any specific reason why my needle gets shakey when building up boost? Is this normal or should i be looking for a problem. Its fine at lower boost then when i whack it to the floor the needle gets really shakey as it rises.
post #10 of 17 Old 03-16-2008, 01:38 PM
eschaner's Avatar
Antique you are running about the right boost. And for the shaking of the needle, It shouldn't be shakey, but a smooth increase. Maybe a bad connection and leaking boost or a bad gauge.
Eric
2002 F-250 SD 4x4:burnout
afe stage 2 air intake
4" dual exhaust w/ delete Y pipe
2" leveling kit
ats turbo housing w/ x-wheel
Tony Wildman chip
Firestone destination m/t's
Ultra 175 Rogue wheels
tri-pod w/fuel pres, ex.temp, boost
Zoodad mod.
Foil delete
Rhino lining
eschaner is offline
