TC question - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-31-2013, 04:35 PM Thread Starter
TC question
I have a 1996 f350 PSD 2wd dually that has only 56,000 miles on it. I currently have done a few mods including exhaust, gauges, tymar intake, IDM mod, HPOP cross over line, and custom 6 position chip. I'm now considering Stage 1's and a better TC. What's a raelly good TC to support these mods. I use the truck to pull a car trailer and a 3 ton dump trailer. The truck only gets driven about 3,000 miles a year and is never beat on. I just want to save my trany before it fails on me.
nrpd diesel is offline
post #2 of 15 Old 05-31-2013, 04:50 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
I use an ambulance/tow truck TC. Jack (1DieselMan, haven't seen him around in a week or two though) knows the site it comes from. Pretty inexpensive since you are not buying name brand. Yes there are a ton better TC out there but unless you are planning on doing a full rebuild (read BTS or Woods) of your tranny at the same time as the TC install if/when your tranny does give up the ghost the guts will find there way back to the TC killing that too. I've done several tranny rebuilds to my own and still this TC type has yet to fail first. Just my
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 15 Old 05-31-2013, 05:34 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Roadrunner iirc is the brand
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 15 Old 05-31-2013, 11:25 PM
Gaius's Avatar
Quoted: 41 Post(s)
I really like my 6.0 converter from Cary. Very strong lockup, and several hundred less than comparable aftermarket converters. Still $600-700 though.
And if you have the tranny out, I definitely recommend the Tugger 2 shift kit for towing.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #5 of 15 Old 06-01-2013, 04:49 AM Thread Starter
I was looking up the roadrunner tc and which one were you talking about, the bad boy 4 clutch one or the three clutch one. The bad boy is twice as much.
Also what is Cary's website so I can look at the 6.0 tc.
Thanks guys for all the info.
post #6 of 15 Old 06-01-2013, 08:27 AM
Quoted: 80 Post(s)
I use the billet towmaster from roadrunner, have absolutely no complaints about it. I was assured the it would handle 400hp with no problem.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #7 of 15 Old 06-01-2013, 09:02 AM
Gaius's Avatar
Quoted: 41 Post(s)
He doesn't have much of a website, but he's a vendor here and very helpful. Also a Jeep guy, which I like.
CT Performance Inc
The stock 6.0 converter is said to be good to 500hp, so the Roadrunner one above sounds like a good option, looks to be around $400. I'll have to try that one next time.
Roadrunner Converters - Phoenix, Arizona Converters - Street, Trip, Towing
05 F350 Crewcab
Gaius is offline
post #8 of 15 Old 06-01-2013, 11:52 AM
Quoted: 80 Post(s)
Jeep guy too, never knew that, now we're talking something that has my attention.
Jack
322000 miles
post #9 of 15 Old 06-01-2013, 05:58 PM Thread Starter
I was thinking about buying the roadrunner 3 clutch one it's only about $70 more and it comes with 2 yr warranty. It wouldn't hurt the tranny any to go with that one right?. Is it worth buying the BTS valve body too?
post #10 of 15 Old 06-01-2013, 07:02 PM
Quoted: 80 Post(s)
No it won't hurt the trans to go with the 3 disc convertor. My valve body is built with sonnax parts for about $75 and I guarantee that it shifts as good as the $250 BTS valve body but if you don't know how to build the valve body or don't want to then the BTS valve body might be the perfect ticket for you.
Jack
322000 miles
