Injector Question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-12-2008, 01:32 AM Thread Starter
sk3322's Avatar
Injector Question
Ok to clear things up, will I need to get head studs for my truck if I go with Stage 1 injectors?
1997 7.3 F250 A/T, AFE Stage 2 intake, 3" DP to 4'' stright piped exhaust , pyro-boost-trans, leveled on 33's
sk3322 is offline
post #2 of 7 Old 03-12-2008, 03:28 AM
Quoted: 5 Post(s)
Send a message via AIM to psu927
no. In fact I believe the stock studs will handle up to stage 2's and whatever you can thow at them. (pretty much, at least stands up to a turbo, stage 2,s fuel system and chip from what I hear).
psu927 is offline
post #3 of 7 Old 03-12-2008, 04:54 AM
There are no 'Stock Studs.' There are head bolts from the factory.
You will be fine with factory bolts and Stage-1's, and Stage-2's, as long as you keep the factory turbo. Once you upgrade the turbo and start pushing lots of air and lots of fuel, then you'll have problems.
Stage-3 hybrids require studs for sure...
Good luck.
An OBS or 2, or 3...
DZL JIM is offline
post #4 of 7 Old 03-12-2008, 02:38 PM Thread Starter
sk3322's Avatar
Good luck.
Oh alright I'm staying with the stock turbo. I really want those stage 1's hopfully I will have the money this summer. How much do you think labor would be to get them installed?
sk3322 is offline
post #5 of 7 Old 03-12-2008, 03:45 PM
No idea.
Figure at least a 3 hour job on an OBS, if you've done it before...
DZL JIM is offline
post #6 of 7 Old 03-12-2008, 04:00 PM
96Ford7.3's Avatar
where would be the best place to get stage-2 injectors for 96 7.3
1996 F350 Crew Cab
Gauges pyrometer, tranny, boost
4" Turbo Back into Dual 6" stacks
SCT Tuner
Stage 2 injectors single shots
Fass fuel system
Coming soon: High pressure oil system, new tunes, bigger injectors, and Built Tranny
96Ford7.3 is offline
post #7 of 7 Old 03-12-2008, 04:14 PM Thread Starter
sk3322's Avatar
The guy above you, DZL JIM.
sk3322 is offline
