dual exhaus. new guy question - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-30-2013, 08:45 AM Thread Starter
Hey guys first off I'm new to the powerstrokes not to Fords.I recently purchased a 97 7.3 e4od with 4.10s. It is ext cab long bed. My question is that it has a 2 piece 3 inch down pipe to 4 inch exhaust. It goes to the muffler and cone out as a y pipe and than goes over the axle and out behind each tire. I would like to know if anyonr has ran dual exhaust one on each side of the truck.in front of the rear tires, and if so how they did it thank you in advance guys.
viggy924 is offline
post #2 of 16 Old 05-30-2013, 12:55 PM
Justin@DP-Tuner's Avatar
Quoted: 54 Post(s)
I have seen it done, but the exhaust system was custom built by a local exhaust shop. I do not think you would be able to do it with any kit you can purchase.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 16 Old 05-30-2013, 03:33 PM Thread Starter
I have the welder extra pipe just wondering if anyone else has some pictures of where it is hung and how it goes past the t case and fuel tank
viggy924 is offline
post #4 of 16 Old 05-30-2013, 03:34 PM Thread Starter
I have the welder extra pipe just wondering if anyone else has some pictures of where it is hung and how it goes past the t case and fuel tank o and I just purchased your tuner lol
viggy924 is offline
post #5 of 16 Old 05-30-2013, 07:40 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
If I'm reading this right Viggy you are asking about a "true dual" exhaust? Like Justine said it can be done but its all custom and you would need double everything back to the manifolds. Two turbos, two mounts, two oiling systems, then two sets of pipes all the way back. Pricey but you will definitely be in a class of few.
If I'm reading this wrong and all you are looking to do is move the tips from behind the axle to in front of the axle then really just ditch the muffler all together, move the Y-Pipe forward a head over to NAPA and grab some 4" tubing and bends. Cut the hangers off the other system pieces not used and make a mount on the drivers side. Just remember that the fuel lines are over there and no shortcuts.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #6 of 16 Old 05-31-2013, 06:32 AM
superduty4x4's Avatar
You could just shorten everything up and re-use the Y, it will be up to you to come up with the bends you need to get them to come out at the angle/location you want. I'd just lay the Y on its side instead of using it vertically like you do with the behind tire exit. Shouldn't be too hard to figure out so long as you can find some locations for hangers.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #7 of 16 Old 05-31-2013, 07:11 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
That would definitely be unique but im wondering if its even feasible only because i think the limiting factor would be the intake manifold. Theres only so much air that can go through in a given time and i would guess that one turbo is already close to maxing out that limit but ill bet it would drastically reduce turbo lag. Would be a cool build for someone with money
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #8 of 16 Old 05-31-2013, 07:17 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I don't think he is talking about a twin turbo set up, I think he wants his current duals in front of the rear tire instead of behind like they are now
OP... you could shorten it like said already, and you have to account for the movement of suspension and driveshaft because they may hit, as well as your front fuel tank, it would have to go under that as well
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 16 Old 05-31-2013, 07:28 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
I'd just use twins off a 5.9c. They're pretty small...
To me the reason that you don't see duel tips in front of the tires is that the tube to the left side has to get around the d-shaft.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #10 of 16 Old 05-31-2013, 07:37 AM Thread Starter
Ya that is what I figured the fuel tank and the ds would b a pain that is why I was wondering if anyone had pictures of it done. A true dual exhaust would be too much I just want my dual in front of the tires. Thank you guys for your help I'm just gonna remove the muffler and see where I can make up some hangers. Eventually when my broken ankle heals I will get around too it and try and snap some pictures my self.
viggy924 is offline
