E-fuel mod. Need help. - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-29-2013, 06:14 PM Thread Starter
Jerzyperson's Avatar
Fixing to upgrade my fuel system. And I have all the lines. But having a hard time finding the hookups for the filters and how to run all the lines... Any help?
Jerzyperson is offline
post #2 of 15 Old 05-29-2013, 06:20 PM Thread Starter
Links would be nice. And how to route the fuel lines.
post #3 of 15 Old 05-29-2013, 06:27 PM Thread Starter
I do have fuel lines and the pump,.. fixing to order the regulator. Justneed to route the lines... And get the hookups for the filters.
post #4 of 15 Old 05-31-2013, 09:35 PM
sethc24's Avatar
I just routed my fuel lines to tie into the stock steel lines. I tied the fuel lines from the rear of the cylinder heads into the factory hard line in the engine valley. And the return lines from the front of the cylinder heads are routed too the fuel pressure regulator and than into the factory return hardline. Underneath the truck i plumbed the electric fuel pump between the tank selector and factory steel line. With some post filtration of course.
On the filter housing i used a bushing reducer and a pipe plug fitting too hose barb.
Hope that makes some sense too you.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
post #5 of 15 Old 05-31-2013, 10:30 PM Thread Starter
The last part slightly confused me. The rest made sense
post #6 of 15 Old 06-01-2013, 11:06 AM
sethc24's Avatar
I used filter housing part # FIL 4407 from napa. The inlet and outlets are 1/2 npt if i remember correctly. So you have to find a way to reduce and connect them too 3/8 fuel hose. A 1/2 npt too 1/4 npt bushing/plug worked for me. Another tip: use thread sealant tape. I tryed using the thread sealant goop and almost every fitting leaked.
sethc24 is offline
post #7 of 15 Old 06-05-2013, 08:39 PM Thread Starter
Isn't 1/2 thread -8? So wouldn't a -8 to -6 fitting from summit work?
post #8 of 15 Old 06-06-2013, 07:55 AM
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
don't know if you have seen this...
http://www.powerstroke.org/forum/7-3...bs-trucks.html
when i did mine i followed mjonesjr's write up almost to the letter
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #9 of 15 Old 06-06-2013, 09:48 AM Thread Starter
When I click the link it takes me to a superchips thread?
post #10 of 15 Old 06-06-2013, 11:02 AM
the baconator
Quoted: 150 Post(s)
works for me. i dunno what to tell you
