Temps - Ford Powerstroke Diesel Forum
post #1 of 19 Old 05-28-2013, 08:43 PM Thread Starter
97Strokin''s Avatar
Temps
What do you guys believe to be safe egts and trans temps in your obs when towing?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
97Strokin' is offline
post #2 of 19 Old 05-28-2013, 09:29 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What kind of grade, how much weight? Hills on your trip?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 19 Old 05-28-2013, 11:11 PM Thread Starter
97Strokin''s Avatar
Its different all the time just looking for some number ranges to keep my temps out of
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #4 of 19 Old 05-29-2013, 09:14 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
You can hold it at 1200*, you can burst it to 1450*, but a good tow tune will cut fuel at higher RPMs to keep EGTs under control. Keep an eye on your Tranny temps.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 19 Old 05-29-2013, 09:22 AM Thread Starter
97Strokin''s Avatar
Yesterday I pulled a 27 1/2 camper and the tranny reached about 195 200 but no more and my egts about 1150 but I don't know how hard I can hold them I have a ts in it
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #6 of 19 Old 05-29-2013, 09:26 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Custom TS or Standard? Tranny under 200* is alright. Cooler the better. I recently installed a 40K tranny cooler from dieselsite and my unloaded temps don't go above 140* now.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #7 of 19 Old 05-29-2013, 10:12 AM Thread Starter
97Strokin''s Avatar
Custom ts how much are them coolers? tough to install?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #8 of 19 Old 05-29-2013, 10:20 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
$130-ish on Dieselsite DieselSite / Tranny Cooler. I'll have to get you a pic tonight but it fits right behind the holes in the bumper. So:
-remove bumper
-set back face up
-position cooler
-drill holes smaller than self tapping screws
-install screws
-run line from tranny output tube -> to rad -> to 40k cooler -> to return tranny tube
-plug or remove stock cooler
-with everything hooked up BUT cooler (and bumper) still flat on the ground in front of truck -start the truck (the cooler needs to be flat on first startup to ensure that the cooler passes -all the air inside of it)
-install bumper
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #9 of 19 Old 05-30-2013, 09:01 PM Thread Starter
97Strokin''s Avatar
So I have this idea, my brother put a bigger cooler in his truck and his old one works fine. So what if I just stack his old one and my current one? Make it flow through two of them before back in the tranny?
1997
F250
3" DP"
4" exhaust
5" Tip
TS 6 Position
17" AR Rims
4" lift
post #10 of 19 Old 05-30-2013, 09:57 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
It would cool even more, I've seen it done with a fan on the second one too, guy has never seen higher than 160 with a 12k trailer from New York to so cal, he claims
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
