Which clutch? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-25-2013, 06:43 PM Thread Starter
c69ss396's Avatar
Which clutch?
I'm needing a new clutch, I can slip mine at will on my hot street setting, higher chip levels are useless. My current clutch only had about 5k on it but its just a stock replacement. I have no clue what my HP is but my mods are in my sig. What clutch should I go with Hp rating wise?
Sent from AutoGuide.com App
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #2 of 15 Old 05-25-2013, 09:32 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Looked into south bend? Heard good things from a few friends about them
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 15 Old 05-25-2013, 10:03 PM
JSchuricht's Avatar
You should be about 300hp with the limiting factor being mechanical fuel and lack of intercooler.
JSchuricht is offline
post #4 of 15 Old 05-26-2013, 10:55 AM
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
get bigger than you need.
i am running a Southbend Con O, i believe it is called (rated 350HP). it is now my weak link
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 15 Old 05-26-2013, 02:47 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Then you should have gone bigger terry
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 15 Old 05-26-2013, 04:21 PM Thread Starter
c69ss396's Avatar
should I go with southbends
1944-5OK - 94-98, 350 hp, 750 ft lbs of torque
or their
1944-5OFEK - 94-98, 450 hp, 900 ft lbs of torque
From what I have read it should match you Hp rating and their web site says too big is just as bad as too small. I plan on adding e-fuel and a intercooler but that shouldn't raise my hp.
c69ss396 is offline
post #7 of 15 Old 05-26-2013, 04:46 PM
the baconator
Quoted: 150 Post(s)
it might bump it a little, but not alot. and it depends if you plan on going bigger. i will need to replace my clutch at some point because i went too small, but maybe i can get another 40k out of it. also LUK and Valair make SMF clutches that might be more inline with what you want.
post #8 of 15 Old 05-26-2013, 04:59 PM Thread Starter
c69ss396's Avatar
it has a relatively new luk clutch in it now, it was fine for stock but it won't hold the new found power.
c69ss396 is offline
post #9 of 15 Old 05-26-2013, 05:18 PM
the baconator
Quoted: 150 Post(s)
LUK, Valair, and SB all make clutches that will do what you want them too. Dual Disc clutches are very aggressive the SB one i run is not, i would like to try the next step up i think that would be a good compromise for me. you would probably be happy with the same one i am currently running so long as you're not planning on upping the power
post #10 of 15 Old 05-26-2013, 05:45 PM Thread Starter
c69ss396's Avatar
Yea I think the 350hp one is the one I'm going to get. I've heard nothing but good things about it. I just hate having to replace a new clutch.
c69ss396 is offline
