opacity testing and 6 pos chip ? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-21-2013, 07:54 PM Thread Starter
My stock 95 f350 has always passed the opacity test in CT.
0.01 or something ridiculously low.....
recently installed 3" downpipe with gutted cat. and a DIY intake.
planning a 6 pos. chip (wildman tunes??? ... undecided)
after my gauge install.
what can I expect for the next opacity test? next year...
not sure how much a cat effects opacity.... I know it was restrictive as all get out.
I think CT allows up to 40% opacity.... for my year truck...
I have read somewhere that the STOCK position on most of these chips is not really stock... but close.
thanks for any info.
JohnT24 is offline
post #2 of 7 Old 05-21-2013, 09:47 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What is opacity?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 7 Old 05-22-2013, 12:12 PM Thread Starter
Originally Posted by 351fifty View Post
What is opacity?
REALLY ???
JohnT24 is offline
post #4 of 7 Old 05-22-2013, 01:52 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Yep, seems like I'm the only one that cares bout your thread the state I live in and the one I register in both do not require anything for my trucks
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 7 Old 05-22-2013, 01:54 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Don't understand the reference either, seems opacity means the degree of light able to pass through
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #6 of 7 Old 05-22-2013, 08:22 PM
jjones96's Avatar
Originally Posted by JohnT24 View Post
REALLY ???
I've never heard of it either... no emmisions here in western wa.
The STROKE
1996 F-250 Powerstroke
7.3 DI T444E.
TS 6 Postion chip
Gloshift max tow gauges
3 inch dp to 5 inch exhaust
diy intake 6637
The Wheeler
1987 Jeep Cherokee
4.0 inline 6
3 inch rustys lift
Cut fenders
33x12.50 r15
Redneck weight reduction
The work truck
2012 Ford F-350 DRW 6.7 Powerstroke
C&M Flatbed
100 gallon slip tank
ProTech side boxes
The Bike
2006 CRF 450R
some go fast parts
Endless other sh*t
jjones96 is offline
post #7 of 7 Old 05-23-2013, 08:19 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
We do have Opacity here in Cali but it only for OTR tractors (diesels 98 and older are exempt). One inspector has a multi-leveled "grey card" and climbs to the top of the stack, the other inspector does a stab test. The first inspector matches the smoke coming from the pipe to the shade of grey on the card and that level tells the Opacity of the engines output. We have to do it every year at my family business. Done by the CHP. It's similar to what the SD have to do. OP the rule of thumb here in Cali is to get inspected on a breezy day as our light duty inspections are not the thickness of the exhaust but how long it hangs. The station inspector will tell us the same thing, to come back when it's breezy. Should work for you too. TW can burn an inspection tune too. Call/Search Cary here on the ORG at CT_Performance to get set up.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
